Go to Post When it is so boring and slow on here in the summer it is funny how all of us just jump at something technical. - sanddrag [more]
Unread 24-01-2015, 22:32
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Ekocycle Issues
Our team is having issues with our Ekocycle. The edges of everything we print start to peel up. On small parts it is ok, but we have a larger bracket that won't fit after it peels up on the edges.
We tried the included glue as well as hair spray to hold it down and both work about the same.
Any ideas?
Rich
Unread 24-01-2015, 22:50
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: Ekocycle Issues
Heat up the plate or use rafts. We don't have ours yet, but it works on our makerbot.
Unread 24-01-2015, 22:54
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: Ekocycle Issues
That happens on our Replicator 2 as well at fills over 70% or so. I don't know much about the Ekocycle but are you able to adjust fill on it? Unless this is an integral part you don't need 100% fill.
If not, a direct option would be to heat the plate because the piece is cooling down too fast and warps.
College sux yo
Unread 25-01-2015, 02:17
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: Ekocycle Issues
The ekocycle comes with glue for gluing the part to the bed while printing which might help with that...Also making the part faster by lowering the infill might help too...I've tried getting it pretty warm in the room...enclosing the machine...hair spray...Also adding raft tabs...or little circles in the corners of the print to help out with warping...Each approach works with varying degrees with our makergear M2 and our Makerbot...Haven't printed anything that big on the Ekocycle yet though we are really happy with the things we have printed.
Hope this helps more than it hurts...
Edoga
Unread 25-01-2015, 02:55
NobleActual NobleActual is offline
NobleActual
FRC #0696 (Circuit Breakers)
NobleActual is an unknown quantity at this point
Re: Ekocycle Issues
I have found that warping on 3D printers tends to be a combination of issues. Print size, speed/quality , infill, and shell settings will all affect your print quality, and any wrong combination of these will cause warping. First, throw down some blue painters tape on the build plate. It works wonders with PLA, keeping things from warping, while achieving a more consistent and repeatable "stickiness" level than hair spray, and without ruining or marking the build plate. While the ekocycle uses rPET, and I admit I have no experience with that, it should perform very similarly. Also, the bigger the print, the more likely it is to warp as the print will start to cool rapidly and often unevenly, causing warping around the corners. While it may seem contrary to what one would usually think, I have found it very effective to stick with the lower quality, and therefore faster, settings on larger prints, as the extruder will travel around faster leaving less time for the plastic to cool and warp before the next layer is deposited. I have never found a real reason to go over 20% infill with 3 or 4 shells at the maximum, and wouldn't recommend any more than that as prints will get incredibly slow and the chance of failure and warping grows exponentially. Finally, make sure your build plate is properly leveled. If it is not, all the settings in the world won't matter, your print will fail and warp every time. I usually level with a piece of paper, and when the extruder is just touching the paper and creating a little bit of friction, its good. Leveling is something that usually requires a certain amount of finesse, along with trial and error to get good at. Hopefully this will give you some ideas and get some great prints going!
Unread 25-01-2015, 20:06
Ideal_Nerd's Avatar
Ideal_Nerd Ideal_Nerd is offline
Team Caption
FRC #3591 (Wild Warbots)
Team Role: Driver
Ideal_Nerd has a spectacular aura aboutIdeal_Nerd has a spectacular aura about
Re: Ekocycle Issues
Have the printer level the print bed and then adjust the z-gap. if it is not level then the edges of the bed will be lower and the first layer wont stick as well.
Evan
Team Captain, CAD leader FRC team #3591.
Westerville Ohio.
Unread 26-01-2015, 00:34
AKA: Rich Lester
Re: Ekocycle Issues
I am thinking it is the heat issue. Our workshop(especially where we put the 3d printer) tends to be on the cold side. Tomorrow we will try and move it someplace less cold and use the rafts idea.
We tried different glues and make sure the gap and level is good before we print. The temperature makes a lot of sense though because it is sitting next to a drafty door and well we are in Michigan.
Unread 26-01-2015, 00:38
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Ekocycle Issues
If you can avoid letting the heat from the machine escape. 3d printers generate a good amount of heat by themselves and by keeping it in, it can also help.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 26-01-2015, 07:05
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Ekocycle Issues
We've been fighting temperature issues as well. Here's the response I got from the Ekocycle support:
Originally Posted by EKOCYCLE Support
To resolve the Temperature Error, could I kindly ask you to do the following:
1. Please remove both cartridges without using the unload function and unplug the machine.
2. Wait about 10 seconds and plug it back in.
3. Now please go through the reload cartridge function for both (make sure the dongles are completely clicked in place) and rerun a print.
This will fix the issue.
Hi!
Unread 31-01-2015, 13:58
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
Re: Ekocycle Issues
We are having a temperature error as well.
Code: T14
Temp: 247C
We tried the suggestions you posted from Ekocycle support but it didn't resolve the issue.
Anybody have this issue and were able to resolve it?
Larry Lewis
FIRST Team 1511 - Rolling Thunder
Team Leader
2013 - Present: Systems Engineer - Viewpoint Systems
2004 - 2013: Lead Test Engineer - Harris RF Communications
www.penfieldrobotics.com
Certified LabVIEW Architect
"I haven't failed, I've found 10,000 ways that don't work" ~Thomas Alva Edison
Unread 02-02-2015, 11:32
The Spiky Hair Guy
Re: Ekocycle Issues
Just called customer support and they said a key item is to make sure the dots on the print heads are lined up when they are installed. That did not resolve our issue but maybe that will work for others.
Also they said to try to swap the cartridges if that doesn't work. I will be trying that tomorrow.
Larry Lewis
Team Leader
