Go to Post Well, we put it in the bag at 11:58 last night. Needless to say we had to pull guys off of it to put it in the bag. I hope we didn't miss somebody and bag him up too. - jimwick [more]
Unread 23-01-2015, 16:37
zenged zenged is offline
FRC #2875
zenged is an unknown quantity at this point
Unhappy Need help with USB camera in smartdashboard!
Initially my team couldn't even get the network camera to work... after a long 3 days we figured out we needed to run smart dash in 32 bit. Now we want to get a USB Camera working.. its been about 5 days since we started to attempt to solve this problem. we have tried everything about usb cameras in the API (http://first.wpi.edu/FRC/roborio/rel... SBCamera.html)
yet it still dose not work. Please help we're desperate at this point. Thanks!!
Unread 23-01-2015, 17:10
Re: Need help with USB camera in smartdashboard!
Have you tried the Simple Vision example? It shows how to use the CameraServer class.
Unread 23-01-2015, 17:31
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Where can I find this example?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 23-01-2015, 17:46
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
We are running Java and this post helped us. We added the code in robotInit() (Iterative Robot) and we had a USB camera image displayed in the standard dashboard while the robot was connected to the driver station, even when disabled. This code should be portable to C++ also.
Unread 24-01-2015, 20:30
In the eclipse example projects.
Unread 25-01-2015, 20:06
Rosbots Rosbots is offline
FRC #5572
Rosbots is an unknown quantity at this point
If you get a broken pipe error you are probably using a 64 bit version of the JDK. Switch to the 32 bit version as the camera will not work otherwise..
Also on the simple vision example you may need to change "cam0" to "cam1".
Check the Roborio web page to see where the camera is attached.
Good Luck,
Stefano
Rookie Team 5572 - Rosbots
Unread 27-01-2015, 16:51
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
We are having the broken pipe error and were wondering how to actually change the jdk to the 32-bit version. We are using windows 7 64 bit eclipse and java. Does it matter if we are using C++ or Java?
Thanks.
Unread 27-01-2015, 18:38
TheOracle TheOracle is offline
TheOracle is an unknown quantity at this point
Thanks.
I'm having the exact same problem. If anyone has any ideas, it would be extremely helpful.
Thanks,
Unread 30-03-2015, 13:17
stopyourself stopyourself is offline
FRC #2335 (Sargon)
stopyourself is on a distinguished road
Is there another thread with this answer? I cannot find x32, and am receiving the same errors.
2013-2016: Team 2335
