Go to Post I think a lifetime of learning properly and then teaching others and inspiring the youth is more important to myself at least than being on the news for a couple seconds during a voice over. - Elgin Clock [more]
Unread 26-01-2015, 12:11
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Mecanum wheels under varying loads
Ive also been curious about 'perfecting' a mecanum drive system by taking the load on each wheel and programming the drive to account for the uneven loading. All papers I found only referenced the geometric center of the base, not the center of gravity. I have a pretty good understanding of how they work, and I feel like there should be a way to incorporate the different normal forces into the reverse kinematics, but unfortunately I've come up short on figuring out the calculation myself.
So I'll ask too: Has anyone ever done a write up on the reverse kinematics with uneven loading or even written some code to deal with it? This seems like something Ether would have addressed in the past, but I can't find anything for it.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 26-01-2015, 12:21
assuming each wheel is being driven at the kinematically correct speed, any deviation from the kinematically predicted behavior, due to uneven loading, would mean that the bot is no longer behaving "holonomically" -- there is wheel scrub -- and this would require an analysis of the forces involved.
Unread 26-01-2015, 12:30
dellagd's Avatar
AKA: Griffin D
Interesting. I'm guessing doing the complete analysis would be pretty complicated if there aren't any papers about it. I wonder if a good estimation could be made that works well enough in practice?
Unread 26-01-2015, 12:58
Yeah I think so. Alan's post#16 does a pretty good job explaining why load affects mec behavior and possible ways to deal with it.
Other options to deal with it involve using actual vehicle motion sensors (e.g. gyro, encoders on follower wheels, etc) to make corrections to the driver's commands.
Unread 26-01-2015, 12:39
Varying the normal force "load" on each wheel has two primary effects. One is a subtle change in the wheel speed vs motor voltage. That can be compensated for using closed-loop control of wheel speed. The other is a significant change in the maximum thrust that the wheel can apply before slipping. That one is not so easy to account for, though I suspect monitoring the motor current can provide a way to do traction control and turn the wheel slip problem into a maximum robot acceleration problem.
