Go to Post "But from a real life standpoint, that looks like something the evil villains in a superhero movie would use to get around in" Reading the phrases "real life" and "evil villains in a superhero movie" in the same sentence makes me giggle. - Alan Anderson [more]
Unread 25-01-2015, 20:10
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
PWM Duty Cycle
Does anyone know how to read a PWM duty cycle on the roborio?
Unread 25-01-2015, 20:16
Re: PWM Duty Cycle
Some teams filter it to create an analog signal proportional to duty cycle, then run it into an analog input.
http://www.chiefdelphi.com/forums/sh...68#post1432868
Unread 26-01-2015, 17:09
DonRotolo's Avatar
Back to humble
FRC #0832
Re: PWM Duty Cycle
Bear in mind that duty cycle is not the salient value in a PWM signal used for controlling motors in FRC. Instead, we use pulse width, varying from about 1.5 mSec to about 2.5 mSec, with varying amounts of time between pulses depending on which motor controller is being used.
I know you know this, but for others reading this thread in the future they should be aware of this detail.
Unread 26-01-2015, 17:20
Re: PWM Duty Cycle
Another detail to be aware of:
The US Digital MA3 and Austria Microsystems AS5145 encoder datasheets recommend duty cycle -- not pulse width -- decoding of their PWM signal outputs.
