Go to Post What, there is life outside of CD? - JB987 [more]
Unread 26-01-2015, 16:38
Charger's Avatar
Charger Charger is offline
AKA: Yiğit Korkmaz
FRC #3646 (Integra)
Charger is an unknown quantity at this point
How to build a battery charging station??
My team thinks of building a battery charging station but we actually dont know how to build it properly. Does anyone can give us tips or explanations to build it properly, safely and cheaply?
Unread 26-01-2015, 17:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: How to build a battery charging station??
Start with thoughts of how to store multiple batteries. How many batteries? Depends on your team, but several at least.
Then consider how you're going to move those batteries from wherever to your pit. Wheels? Sherpas? Come up with an idea. Remember batteries weigh a lot, especially 'several' batteries.
Then consider charging. How many need to be charged at once? Where will the chargers go, and do they get enough ventilation air (they do get warm) there? Are they mounted into the 'station' or just put in there, and if mounted how? (Velcro, screws, clips, something). How do they get electricity? Can you see the lights on the chargers (you need to...)?
Work through these considerations. During that thought process, your team will definitely come up with more questions, which should be answered (ideally on paper).
Then search the interweb and ChiefDelphi for images of other teams' battery charging stations, which will give you some ideas, so you can then use the answers to the questions above to a way to build a battery charging station.
Our first station was essentially a bookshelf on a hand-truck. The batteries were carried low, and then moved to the top where the chargers were at competition. A power strip for the 6 chargers completed it.
Let us know what design you came up with please!
Unread 26-01-2015, 17:39
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
The popular choice tends to be shelving on a handtruck. Our team did something along those lines too. We popped a shelving unit on a handtruck that was big enough to fit 2 batteries in a row, with three rows stacked. Powerstrip mounted on the back and a bottom row with three battery chargers in it. Something different we did do, however, was attach voltage readouts for each battery in the station to see how much power something had if it wasnt charging.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 26-01-2015, 17:51
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Ours is a Harbor Freight handtruck with a plywood shelf mounted onto it that holds ten batteries. We have a ten bank Battery Tender charger mounted up top that keeps the batteries maintained. I uploaded a photo to CD and it should be in the gallery soon. We used Anderson connectors on all of the connections as well so everything stays nice and tidy.
Here is our cart: http://www.chiefdelphi.com/media/photos/41211?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 26-01-2015, 17:59
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
I agree with what has been said but like to add that its beneficial to mount the charger on top or on the sides of the charging station. Also, make sure you know how much space you have in your pit.
On the team i'm on, 1885, we have a shelf-like design, with a charger that can charge 6 batteries mounted on top, with two additional single chargers on the side. we also have wheels on it. Larger wheels are better because when transporting in and out of arenas its likely that you'll encounter "tough terrain" (meaning lots of bumps and potholes). Don't forget to make it look nice! put a couple coats of your teams colored paint on it.
Hope this helps and send pics when it's done!
Alumni from 75 and 1885
Unread 26-01-2015, 18:46
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
You could buy this one: http://www.robopromo.net/product_p/rp_br.htm
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 26-01-2015, 19:17
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Our battery charger has the chargers built in, but additionally it is a power station. Our new one (New for 2014 season) holds and charges six (IIRC) batteries, and also has a fold out table attached to one side, which is really nice to have in the pit area. Also, we have additional space on top to charge our drill batteries (which is really nice to have a designated space for) and extra power strip space to support a few laptop chargers, cell phone cables, power tools, etc. Make sure you include a spot for your drill batteries and at least a few extra power strip spaces for this reason. We also keep our older bookshelf style charger in the shop to charge our test batteries so we can keep our competition batteries separate.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 27-01-2015, 05:38
Charger's Avatar
AKA: Yiğit Korkmaz
FRC #3646 (Integra)
Also, in the competition, I saw teams charging their batteries just in 30 min. How is it possible? It takes us about 2 hours to charge just one battery properly. And is there any way to use 1 charger to charge more than 1 battery?
Unread 27-01-2015, 07:22
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
The only legal method would mean they aren't discharging their battery too much. Or their charger isn't very good and isn't fully charging the battery.
There is, but you should only use a properly made charger for it. Andymark sells chargers designed to charge 3 simultaneously. There are others out there as well.
A few years ago, we took plywood and made a station with three drawers in it, plus extra room higher up. Each drawer could hold three batteries and an Andymark triple charger. It's worked well for us. We use some of the extra room in it for supplies and the safety kit.
Unread 27-01-2015, 08:58
philso philso is offline
FRC #2587
Without more information, it is not possible to say whether the team you saw really "charged their batteries in just 30 minutes". If their batteries were only slightly discharged, topping them up would not take very long. A charger with a very high charging current would charge the battery very quickly but is not legal and would most likely damage the battery.
If you are asking if it is possible to use one LEGAL battery charger to charge several batteries connected in parallel, the answer is a qualified yes. The state of charge of the batteries being connected in parallel will not be the same. Often, teams use batteries from different manufacturers so the internal resistances will be somewhat different. Putting a random mix of batteries in parallel and connecting them to one current source (not a multi-output charger) will mean that the charging current for each battery will be different and the charging time for each battery to reach full charge will be different. If the charger used is a trickle charger, the currents will be low enough that the battery can be left charging at that current for a long time without significant damage so eventually, after a long time, all the batteries will reach full charge, one after another. If the charger is not a trickle charger, it is possible that some of the batteries become overcharged, damaging them permanently.
