Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 26-01-2015, 18:45
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: Need help with arduino to i2c on roborio!
Originally Posted by cad321 View Post
How might one go about implementing this? Would I just plug the arduino into the usb port, set my baud rate and my port (not sure which port), and then finally use the Serial.read() command to receive what I had output over the arduino serial?
That's right. I haven't tried it, but you might be able to see the name of the serial port from the web interface.
