Go to Post Do it the good ol' American way and throw money at the problem. In other words, get out of there and call a professional to take care of it. - sanddrag [more]
Unread 25-01-2015, 01:24
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Random questions from first year programmer
Originally Posted by Commando386 View Post
To talk about how the motors are backwards I agree how setup might be backwards as it has happened to me but also make sure that the electrical wiring is not backwards. I can't really explain it well as I am Software Lead and not Electrical Lead. If not you could always insert a negative block (It's under Numerical and it has a -x on it) and attacth it to you inputs and it will flip your Y-axis controls (forwards and backwards) and that should fix it software wise. Also a note that in autonomous coding forward is negative and backwards is positive values. I have always run into this situation in the old labview and the new one.
If you do have the motors swapped, it can be fixed in at least three ways as I believe the post above was trying to explain:
  1. Software (swap left and right port numbers or variables in the code)
  2. Controls (swap one end of the PWM cables, either the controller or the RIO)
  3. motors - swap the wiring from motor to controller at one end
  4. Actually, you could physically swap the motors along with the wires, but that would be more work than necessary
Unread 26-01-2015, 19:21
Wawa's Avatar
Wawa Wawa is offline
Wawa
FRC #3659 (Mighty Patriots)
Wawa is an unknown quantity at this point
Thanks guys! I went down the list of possible issues and it turns out the motors weren't connected to the right controllers. I swapped the positions of the PWM cables and it worked perfectly!
Thank you all so much!
Our Plan B is our Plan A.
Unread 08-02-2015, 22:01
Wawa's Avatar
Wawa
Alright, so programming has run pretty smoothly. I've got everything for teleop set and running perfectly, thanks to all of you wonderful people. This will probably be my one of my last questions:
How do I program pneumatics and another motor(for the arm) in autonomous?
I can figure out the driving through all the examples, but I can't find a lot on pneumatics and extra motors.
