Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
View Poll Results: How many teams will attempt to use more than one air compressor at a competition?
None, everyone reads and understands the rules 14 20.00%
One per competition at most 26 37.14%
One for each 20 teams at a competition (5%) 23 32.86%
More than 5% of the teams 6 8.57%
Something else (post comments below) 1 1.43%
Voters: 70. You may not vote on this poll
Unread 26-01-2015, 19:48
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Re: R68: One and only one compressor
Originally Posted by DonRotolo View Post
The way I see it, R68 is extremely clear that a second compressor (such as another ViAir on the cart, or in the pit, or a shop [120 V AC] compressor) anywhere at the competition is just not allowed.
Am I mis-reading this rule?
Anyone want to take bets on how many teams attempt to use more than "one and only one" compressor at competition?
Don, I think there are a couple of points where I might differ with your interpretation of R68. Here is the rule:
R68
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not
exceed nominal 12VDC, 1.05 cfm flow rate.
First, in the event that a team suffers a complete failure of the robot compressor would you disallow them from replacing it with a like for like unmodified compressor from the spare parts station or from their own parts drawer?
Second, your interpretation fails to give any meaning to the words "on the ROBOT". IMO the rule is worded to clearly indicate that the stored compressed air in a robot's pneumatic tanks is to be provided by that robot's on-board or off-board compressor not by some other source. The purpose of the rule is, I believe, to disallow the use of a compressor identical to that of the robot's on-board compressor to fill the pneumatic tanks pre-match while keeping the on-board compressor cool and fresh for the match.
Finally, as worded, R68 clearly prohibits the use of a shop compressor for supplying compressed air to "the ROBOT" due to the voltage and flow rate specifications. Shop compressors are not prohibited from being present in the pits under this rule.
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
