Re: Two Motors one PWM help?
I've never seen anything outlawing PWM splitters. In fact, they were included in the kit for years. Maybe as recently as 2013? Now back to OP: are all of these motors drive motors? If so, why not have both sides on PWM splitters or both sides on two PWM outputs. Seems like things are necessarily complicated. |
R57 Every relay module, servo, and PWM motor controller shall be connected to a corresponding port (relays to Relay ports, servos and PWM controllers to PWM ports) on the roboRIO or via a legal MXP connection (per R58). They shall not be controlled by signals from any other source. This actually provides that no other source can be used to provide control for the listed devices except the RoboRio. This is safety issue in that we know the RoboRio can be disabled/enabled via the FMS. Other devices likely would not provide this level of control and might cause robot movement when the robot is disabled. That is the underlying reason, active MXP boards must be pre-approved by FIRST Engineering. To the OP, how are your two motors designed to operate? Are they connected together on a mechanism? Can you tell us what indications on the motor controllers are present? |
Al, thanks for the verification. |
[IMG] [/IMG][IMG] [/IMG][IMG] [/IMG] |
A few things are wrong here.
If all four of these motors are for driving, then you need some consistency. Either:
PWM 0 and PWM 1 are signals for opposite sides of the drive train. So those are where your two splitters should come from. One splitter for each side. The Arcade Drive is mixing the joystick x/y to produce the correct PWM0 & 1 outputs. The Dual Motors isn't compatible that that. Motor Set Output has an incorrect wire. The one with the red dot needs to be removed. It looks like you are trying to treat it like Arcade Drive. It isn't. There are duplicates for Robot Drive Motors, Joystick 1/Axes/Buttons, etc. setting every one of these in two places. Only one will win. Last edited by Mark McLeod : 27-01-2015 at 14:55. |
#7
