Go to Post I still say animation is the illegitimate child of the FIRST family locked away in the attic and never spoken about. - Koko Ed [more]
Unread 27-01-2015, 09:00
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
Javadocs for F310 Gamepad
Where are the Javadocs for using the Logitec F310 Gamepad or the XBox game controller? I find instructions on a 3-axis (X Y Z) Joystick but not for the 2-stick gamepad.
For those whose standard reply is to connect to DriverStation USB display - we did that and the right controller of the game pad showed X and Y motion and the left controller did nothing. since the display was identified as Joystick 1 and Joystick 2 it was not looking for a second control stick on the same port.
So how do we access the second controller?
Unread 27-01-2015, 09:02
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Javadocs for F310 Gamepad
You treat it just like a joystick, but use the getRawAxis(int axis) method to access each axis.
Unread 27-01-2015, 09:54
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Be sure the 'mode' button on the gamepad is not active.
If you're unsure about the mapping of sticks and buttons on the F310, you can refer to this. Alternatively, use the Logitech Profiler to define your mapping.
2012 - 2015 • Team 2601
Unread 27-01-2015, 10:54
So all of the methods for direction and magnitude will not work or have no equivalent?
Which controller is axis 1 and which is axis 4? How is X mapped to an axis and how is Y mapped to axis. There are all kinds of buttons on the gamepad, colored, non-colored, triggers, settings, etc. How are these mapped to the joystick? The older Attack joystick has numbers on the buttons and those numbers correspond Javadoc for Joystick.
One would have expected that the Javadoc for the gamepad should include similar details about the mapping and use.
Unread 27-01-2015, 10:59
Flywheel Police
Different controllers are mapped differently. An X-Box controller is mapped differently than a PS4 controller. If you plug the controller into the driver station the setup tab will show you the values of the axis and buttons.
Unless the axis map in a similar way that the basic joystick does the get magnitude methods and the like will not work. I know the left joystick of a PS4 controller maps to the first 2 axis, so that would match up to the getMagnitude() method.
There is no Gamepad class as far as I'm aware, so there is no javadoc.
http://wpilib.screenstepslive.com/s/...1881-joysticks
