Go to Post ...thinking and learning never go out of style. - Rick TYler [more]
Unread 27-01-2015, 11:33
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
2015 Dashboard - How to use Custom Tab
Dear CD,
I am a little confused how to take advantage of the Custom Tab in a new Custom Dashboard for our team. The driver station parameters I passed in 2014 are no longer available. I would like to display a dozen, variables
in this tab. Does someone have an example they can post? I have looked through the online documentation and Labview tutorials and have not found one yet... Of course the changes would most likely occur in both the TeleOp.vi and Dashboard Main.VI
Best regards.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 27-01-2015, 12:47
Re: 2015 Dashboard - How to use Custom Tab
There is an example built into the default programs.
In the default Dashboard About halfway down you'll see a block of variables used on the Basic tab.
In Teleop.vi you'll see corresponding reads of some of those same variables.
Here is another example that places new variables on the Custom tab.
It shows two boolean variables Marc 1 and Marc 2 that are explicitly treated as SD variables.
It also shows another two boolean variables Marc 3 and Marc 4 that are implicitly treated as SD variables.
All four are read on the robot side in Periodic Tasks.
Unread 27-01-2015, 12:51
By default, the custom tab will automatically bind any control put into it to a SmartDashboard variable that can be read or written on the robot.
So there shouldn't be any need to change code in the dashboard unless you want a fancier display or calculation before display. If you do, the top loop shows an example of reading variables and displaying them in charts.
Greg McKaskle
Unread 27-01-2015, 13:20
marccenter's Avatar
Mark and Greg,
Thanks for the example! I was also confused because when I dropped a new indicator into the Dashboard Custom Tab I could not see the parameter in the block diagram panel. It took me a while to find the command to flip between both locations in the front panel and block diagram which located the parameter.
I also dropped a control into the Dashboard Custom Tab.
The indicator will receive the value sent from TeleOp.vi via the SD write VI correct? See picture.
Name:	Dashboard Custom 3548.png
Marc Center
Last edited by marccenter : 27-01-2015 at 13:23. Reason: swap control with indicator?
Unread 27-01-2015, 13:54
That should work fine.
Unread 27-01-2015, 17:31
icq10 icq10 is offline
icq10 is an unknown quantity at this point
Is it allowed to modify the other tabs? Or even the color/appearance?
Unread 27-01-2015, 18:31
It's for your use only.
You can change everything, nothing, or replace it entirely with something else.
