Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 27-01-2015, 11:34
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Carbon Fiber
Just wondering if any other teams will be using carbon fiber this year?
Unread 27-01-2015, 11:36
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Carbon Fiber
yes
Unread 27-01-2015, 11:47
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Carbon Fiber
I think we'd be interested, but do not know the techniques for making it. Can someone post information on making it? I remember running into Carborundum a few years ago and was impressed with their material.
Unread 27-01-2015, 12:19
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Re: Carbon Fiber
Will Team 1619 be using carbon fiber on our robot this year?
Not likely.
Will there be at least two (to use the word "teams") teams that use it this year?
Absolutely. I have seen carbon fiber on robots at every regional that I have attended in one shape or another. I would be very surprised if there weren't teams using for its lightweight properties again.
It's not done until it's overdone!
Unread 27-01-2015, 12:25
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Carbon Fiber
If by carbon fiber you mean wood, then yes.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 27-01-2015, 12:31
AKA: Rich Lester
Re: Carbon Fiber
We are using quite a bit of it this year. First time we were able to so we are jazzed. Such an interesting material. Looks like metal but weighs like plastic.
Unread 27-01-2015, 12:48
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: Carbon Fiber
Wood is primarily (40-45%) fibrous cellulose (C6 H10 O5), which contains carbon. Therefore wood = "carbon fiber"
Unread 27-01-2015, 12:55
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: Carbon Fiber
I'm glad someone got my joke!
Kevin Li
596 - Sciclones
mrnoble's Avatar
teacher/coach
Re: Carbon Fiber
We have set up a vacuum press. Here's what we do:
  • 3/4" thick plywood w/ melamine (resin doesn't stick to melamine surfaces)
  • whatever the object is being formed around. This could be flat (thus the melamine), or some other shape. make sure it is covered in material that the resin doesn't stick to, or is intended to be part of the structure.
  • epoxy resin
  • carbon fabric
  • more resin
  • mylar sheet, for the smooth shiny finish that we are used to seeing on carbon
  • nylon "fluff" to absorb extra resin
  • "bag" material. this is very tough and stretchy plastic that is taped down to the melamine.
Talk to a supply shop, they can hook you up with the right materials. Oh, and you need a pump and a suction cup, too. These are not cheap. In fact, all of that will set you back a fair penny. Make sure you intend to use it for the long term before investing in all the setup, and make sure what you are using it for actually benefits your robot. We are using it as a wrap around a 1/8" thick Baltic Birch belly pan sheet. It makes it light, strong, and stiff.
Unread 27-01-2015, 13:06
AKA: -matto-
FRC #1410 (Kraken)
Re: Carbon Fiber
... and also electrically conductive. Be careful!
Solar car carbon fiber skins can catch on fire if the cells are not properly isolated ...
Unread 27-01-2015, 13:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Carbon Fiber
We spent a few minutes last night talking about "real" carbon fiber, then cut our claw parts out of 1/4" birch plywood.
We also made the center brace for our robot, we used a 2x6 since a 2x4 was a skosh too tall, and it was easier to rip the 2x6 to the proper width.
Engineering is an interesting game.
Unread 27-01-2015, 13:16
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Carbon Fiber
We're using a whole lot of carbon fiber composite. We're using both a vacuum bag method like mrnoble (with thin aluminum replacing the melamine coated wood), and just doing a wet lay up of carbon and glass fiber sheets with epoxy and then compressing it on smooth, waxed surfaces. Using compression is easier, but you have to be careful with how much epoxy gets put in because there is less pressure trying to push it out of the fibers. If you use too much epoxy, the fibers will be farther apart, weaker, and heavier. You also have to make sure the surfaces are good ones, we've had issues with the epoxy sticking to some materials and with glass shattering under pressure when used.
Unread 27-01-2015, 13:55
dchartley dchartley is offline
FRC #3684
dchartley will become famous soon enough
Re: Carbon Fiber
I haven't used carbon fiber or fiberglass on robots but I've used them extensively on electric race cars (Electrathon America). You can use just about any material (except styrofoam which will melt even through plastic) for a mold then cover with the heat shrink plastic you can buy for window insulation. Shrink it with a heat gun and its ready to use. If you want to make multiples of the same item it works better to make a positive mold (buck), then make a negative mold, wax the snot out of the negative mold (use release wax if you can find it) then make the parts. I never used a bagging system, only wet lay up, but if you coat the interior of the well waxed mold (I usually did 10-15 coats of wax on a new mold) with epoxy, then the layers of cloth, making sure all the cloth is coated and then put your buck on top (with the plastic cover if necessary) then add some weight and set overnight it will give results as good as many bagged systems. I'll post some photos in the gallery section.
Doug
Unread 27-01-2015, 17:53
mistakwa's Avatar
mistakwa mistakwa is offline
FRC #0548 (Robostangs)
mistakwa is on a distinguished road
Re: Carbon Fiber
yes
Unread 27-01-2015, 22:15
BigBen's Avatar
BigBen BigBen is offline
FRC #3494 (The Quadrangles)
BigBen will become famous soon enough
Re: Carbon Fiber
While I have been with our team for only the last year and a half, they pride themselves that there has been at least some functional component made of carbon fiber each year, even if it is just shields and the electronics base.
As mentioned above, be careful as the carbon fiber is electrically conductive so you have to insulate any items that do not like to be electrically grounded (*cough* old cRio case *cough*). What we did last year was use a Kevlar sheet on one side instead of the top layer of carbon so it was insulated, and the mountings were with either velcro or double sided tape.
