Go to Post Aim for the stars – you just might hit a planet. - Leo M [more]
Unread 24-01-2015, 11:57
rnay rnay is offline
FRC #3405
rnay is an unknown quantity at this point
2015 RoboRio Imaging Error
We've tried imaging our RoboRio on two different computers and on our classmate, via both USB and ethernet, and get the same error every time. We have the latest 2015 NI update installed.
This is a screenshot of the error we get:
Have any other people had this issue and found a solution?
Update: We tried imaging again, with the same error, and now we get a constant blink of both the power and status lights (unrecoverable error!?). Previously after the error, the power light would be solid and the status light would have a pattern of 2 blinks (software error).
Unread 24-01-2015, 17:56
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: 2015 RoboRio Imaging Error
Try turning off windows firewall
Try disabling all other network adapters.
Its recommended to only image using USB.
You may have to put the RoboRio in safe mode to try again.
Brian K
Team 1225 Robotics Mentor
Unread 24-01-2015, 21:36
Did you extract the NI Update files into a folder before running the update? If you try to run it from within the .zip file, things usually don't work properly.
Unread 27-01-2015, 13:23
FRC #3405
Thanks for the suggestions. Yes, the update files were extracted and we tried safe mode. We eventually got it to work by following directions from this thread: https://decibel.ni.com/content/message/91743#91743
We imaged it with our Classmate over ethernet, and setting a manual ip (169.254.11.11) for the classmate.
