Go to Post Long Live FIRST! - IndySam [more]
Unread 27-01-2015, 13:25
Hugo_Klepsch Hugo_Klepsch is offline
FRC #2200 (MMRambotics)
Hugo_Klepsch is an unknown quantity at this point
Exclamation [WARNING][DO NOT UPDATE WPI PLUGINS] Too many authentication failures for admin
We have been able to build and upload code for the past two weeks. I am uploading\deploying different versions of confirmed working code.
We were able to upload and deploy the same code yesterday night, and have made no changes to roborio configuration since then.
Today we saw the WPI plugins for eclipse were updated, we updated two of the four programming computers, and only those computers have the following error:
[sshexec] Connecting to roboRIO-2200.local:22
[sshexec] Caught exception: SSH_MSG_DISCONNECT: 2 Too many authentication failures for admin
Until a fix has been found, do not update your plugins!
Unread 27-01-2015, 14:10
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Re: [WARNING][DO NOT UPDATE WPI PLUGINS] Too many authentication failures for admin
You're having authentication problems. Edit your build.properties file within the USER/wpilib/java/current/ant directory.
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 27-01-2015, 17:42
Talking Re: [WARNING][DO NOT UPDATE WPI PLUGINS] Too many authentication failures for admin
Thanks for showing us the file to edit!
Inside the build.properties file there us a username and password entry.
By default (I assume) the username is lvuser, with a blank password.
We changed that to the correct logon for our admin user, (configurable through the roborio webserver) and everything worked again!
Imgur links:
Thanks
Name:	Screenshot from 2015-01-27 17:34:44.png
ID:	18015  Click image for larger version
Name:	Screenshot from 2015-01-27 17:34:54.png
ID:	18016  Click image for larger version
Name:	Screenshot from 2015-01-27 17:35:09.png
Unread 27-01-2015, 18:53
So, to clarify, the problem was not with the updated WPILib plugins at all but with the fact that you have modified the user accounts on your roboRIO?
Unread 27-01-2015, 19:06
AKA: Lucas Alvarez
Yep
Unread 27-01-2015, 20:04
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
You should probably change the title of this post then?
Unread 28-01-2015, 19:18
Not necessarily, that user account was working yesterday, and no changes were made to users on the roborio between the time that they were working and the time that they were not.
The WPI plugins, however were updated, therefore I can only assume the only changed variable is somehow a cause of the breakage.
Unread 28-01-2015, 19:20
Code runs as the lvuser/blank password account
admin should remain as admin/blank password
Don't change the account setup.
Unread 30-01-2015, 19:58
The wpi plugin update process deletes almost everything in the wpilib folder, including any customizations you made to the build.
Rather then changing the properties file included in the wpilib plugins, a less brittle approach would be to change the build.properties in the project directory to have the username and password you want.
