Go to Post I know it's hard to believe, but there actually IS life after FIRST. - jleibs [more]
Unread 27-01-2015, 15:07
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
Gyro class issue?
I'm using an Analog Devices ADW22307 gyro and haven't been able to get a reading out of it using the gyro class.
We are programming in Java and the code is:
Gyro gyro = new Gryro(1);
gyro1.reset();
angle1 = gyro.getAngle()
When we try to print the value to the SmartDash we get nothing. We tried several other gyros with no luck. We tried defining an analog input channel to directly get the voltage output from the gyro, and that works. The voltage is 2.45V when the gyro is stationary as expected, and then we see it increase or decrease if rotated the gyro, so it seems the gyro itself is working.
Has anyone else run into this problem?
Unread 27-01-2015, 15:09
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Gyro class issue?
gyro1.reset();
Can we see a larger portion of your code?
Unread 27-01-2015, 15:10
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Are you resetting the gyro each time you get the angle? You only should call reset() when you want to reset the angle back to 0 (ie. after it has drifted a lot).
Unread 27-01-2015, 15:21
FRC #1493
Here it is. We can plug the gyro into AI port 1 and get voltage readings. When we plug it into port 0, we get nothing. We switching ports, eliminating the analog channel, and using other gyros.
import edu.wpi.first.wpilibj.smartdashboard.*;
import edu.wpi.first.wpilibj.Gyro
import edu.wpi.first.wpilibj.AnalogInput
public class Robot extends IterativeRobot
Gyro gyro = new gyro(1);
AnalogInput ai1 = new AnalogInput(0);
double angle1, voltage1;
public void robotInit()
gyro.reset();
public void autnoomousPeriodic()
public void teleopPeriodic()
angle1 = gyro.getAngle();
voltage1 = ai1.getAverageVoltage();
SmartDashboard.putString("DB/String 6","gyro = "+angle1);
SmartDashboard.putString("DB/String y","ai1 = "+voltage1);
Unread 27-01-2015, 15:22
Flywheel Police
You need to set the sensitivity of the gyro using setSensitivity() so it knows how to convert from voltage to angle. This needs to be in volts/degree/second, this number can usually be found on the gyro's datasheet.
It is defaulting to 0, that is why you are getting a voltage but no angle.
Unread 27-01-2015, 15:23
FRC #1493
I made sure we weren't continuously resetting the gyro
Unread 27-01-2015, 15:25
Flywheel Police
Also, if you can use the code tags when posting in the forums it will make your code easier to read. To do this place [code] at the beginning of the code and /code in the brackets at the end.
Unread 27-01-2015, 15:33
Dartmouth 2020
AKA: lopsided98
Is your gyro connected to input 0 or 1? You created your gyro on channel 1 but your analog input is on channel 0.
Unread 27-01-2015, 15:34
Dartmouth 2020
AKA: lopsided98
Try replacing the first two lines of the class body with this:
Gyro gyro = new Gyro(ai1);
Unread 27-01-2015, 15:50
heuristics heuristics is offline
FRC #3634
heuristics is on a distinguished road
Did you try calling gyro.initGyro() in your robotInit function before calling reset()?
Unread 27-01-2015, 15:51
FRC #1493
I added gyro.setSensitivity(0.007) in robotInit
and I also tried defining the gyro as:
Still nothing.
Unread 27-01-2015, 16:01
FRC #1493
Here's the code now. Still nothing. If I uncomment out the ai1.getVoltage I still get what looks like the proper voltage.
   Gyro gyro = new gyro(ai1);
    gyro.initGyro();
    gyro.reset();
    gyro.setSensitivity(0.007);
    // voltage1 = ai1.getAverageVoltage();
