Go to Post in other words, "always have something to do that will change up your life" - Nawaid Ladak [more]
Unread 27-01-2015, 18:53
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Motors don't work in sync?
Ok so essentially all four of our motors work but the problem is, the left side wheels will run forward while the right side run backward, and vice versa, so all the robot does is go in circles. I'm sure it's a stupid/small mistake but here's what I've got.
[IMG][/IMG]
[IMG][/IMG]
Unread 27-01-2015, 19:00
Re: Motors don't work in sync?
[IMG][/IMG]
[IMG][/IMG]
Software solution: Invert the motors on one side
Hardware solution: reverse the motor wires for each motor on one side*
*NOT the wires coming from the battery to the motor controller
Unread 27-01-2015, 19:33
What he said.
The Motor Open has an Invert node on the bottom.
Unread 27-01-2015, 20:12
FRC #5005
Awesome, thank you both! I won't be able to test until tomorrow but I'm gonna take your word that this will work I'll update if it does! Thanks again!
