Go to Post The FIRST community will always step up in times of need. - nikeairmancurry [more]
Unread 27-01-2015, 19:12
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Talon SR vs SRX
Originally Posted by jtaylor991 View Post
Would they be compatible with our Talon SRs that were included in the 2015 kit of parts? (or are those SRXs? They only say SR) If we have them as backup, could we just hot swap one in, connect the PWM, and be on our way?
Both the Talon SR and the Talon SRX support PWM control. Having said that, wiring the Talon SRX for PWM control requires some modification of either the PWM cable or the Talon SRX signal cables. Once you've made those modifications, hot-swapping either motor controller (and keeping in mind that the Talon SRX doesn't support the fork connectors you might commonly use with the Talon SR) should be simple. Refer to section 1.3.3 on the User Guide for more information.
I saw someone mention the code from NI being wrong concerning mecanum drive in a forum post (although the forum post was deleted in the past few minutes).
mecanumDrive_Cartesian() shouldn't have any issues with the Talon SR or Talon SRX. Issues with the method and CAN Jaguars were reported.
2012 - 2015 • Team 2601
