Go to Post wait a minute...Dave posted a hint here yesterday. but no one has tried to analyze it word by word. has something changed since the kickoff??? - jerry w [more]
Unread 01-26-2015, 12:39 PM
Re: Mecanum wheels under varying loads
Originally Posted by dellagd View Post
Ive also been curious about 'perfecting' a mecanum drive system by taking the load on each wheel and programming the drive to account for the uneven loading.
Varying the normal force "load" on each wheel has two primary effects. One is a subtle change in the wheel speed vs motor voltage. That can be compensated for using closed-loop control of wheel speed. The other is a significant change in the maximum thrust that the wheel can apply before slipping. That one is not so easy to account for, though I suspect monitoring the motor current can provide a way to do traction control and turn the wheel slip problem into a maximum robot acceleration problem.
Unread 01-26-2015, 12:58 PM
I'm guessing doing the complete analysis would be pretty complicated
Yeah I think so. Alan's post#16 does a pretty good job explaining why load affects mec behavior and possible ways to deal with it.
Other options to deal with it involve using actual vehicle motion sensors (e.g. gyro, encoders on follower wheels, etc) to make corrections to the driver's commands.
Unread 01-26-2015, 01:08 PM
Originally Posted by Robot Sans View Post
Yup, thats what i was thinking. They would have to be low friction but not omni-directional. Plastic wheels would be ideal.
Why not omni? and what effect do you think those wheels might have on the mec's kinematics?
Unread 01-26-2015, 01:15 PM
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Why not a ball caster?
___________________
- Tennyson, Ulysses
Unread 01-26-2015, 01:42 PM
howe howe is offline
FRC #5099
howe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to behold
Originally Posted by Tom Line View Post
http://www.chiefdelphi.com/forums/sh...hreadid=133086
http://www.chiefdelphi.com/forums/sh...hreadid=132855
http://www.chiefdelphi.com/forums/sh...hreadid=121317
Google search terms:
mecanum wheel load uneven site:chiefdelphi.com
I usually have much better luck with Google's search than Chief Delphi's.
Thank you Tom, for the information I was looking for.
Thanks for the other tip too, sometimes I just can't help myself.
howe
Unread 01-27-2015, 11:46 AM
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
We currently have a mecanum setup with omni wheels in between.
Unread 01-27-2015, 12:09 PM
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Are the omni-wheels powered?
Unread 01-27-2015, 12:31 PM
in between how? A, B, C, D, or something else?
ID:	18007  Click image for larger version
ID:	18008  Click image for larger version
ID:	18009  Click image for larger version
Unread 01-27-2015, 01:55 PM
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Also, are all the wheels at the same frame height or is the "in between" wheels dropped (by 1/8")?
Unread 01-27-2015, 10:35 PM
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
With the unpowered omni in the middle I am guessing that you may have issues getting over the humps.
Are you using Andy Mark or VEX?
