Go to Post Many people read ChiefDelphi, not just members of FRC teams. - JaneYoung [more]
Unread 27-01-2015, 18:59
jtaylor991 jtaylor991 is offline
AKA: Jackson Taylor
FRC #1827 (The Hive)
jtaylor991 is an unknown quantity at this point
Talon SR vs SRX
Hello,
I made the suggestion that our team purchase one or two extra Talon motor controllers to have on hand. I checked both AndyMark and Cross The Road's website and they both say the Talon SR has been discontinued. AndyMark said it was being replaced by the SRX. The pictures for the SRX look totally different -- whole other beast.
This concerns me:
Would they be compatible with our Talon SRs that were included in the 2015 kit of parts? (or are those SRXs? They only say SR) If we have them as backup, could we just hot swap one in, connect the PWM, and be on our way?
I saw someone mention the code from NI being wrong concerning mecanum drive in a forum post (although the forum post was deleted in the past few minutes). We're using mecanum (Cartesian) drive, so this is something I/we would like to know about as well if anyone has any sources on that.
Thank you for any and all of your time!
Jackson Taylor
RoboJackets FRC Team 1827
Unread 27-01-2015, 19:05
Re: Talon SR vs SRX
When you see a post like that from someone who has a total of 1 post, you should take it with a grain of salt.
Unread 27-01-2015, 19:12
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Talon SR vs SRX
Both the Talon SR and the Talon SRX support PWM control. Having said that, wiring the Talon SRX for PWM control requires some modification of either the PWM cable or the Talon SRX signal cables. Once you've made those modifications, hot-swapping either motor controller (and keeping in mind that the Talon SRX doesn't support the fork connectors you might commonly use with the Talon SR) should be simple. Refer to section 1.3.3 on the User Guide for more information.
mecanumDrive_Cartesian() shouldn't have any issues with the Talon SR or Talon SRX. Issues with the method and CAN Jaguars were reported.
2012 - 2015 • Team 2601
Unread 27-01-2015, 19:14
Re: Talon SR vs SRX
And reported fixed in the 1-16 update: http://wpilib.screenstepslive.com/s/...ates-changelog
C++\Java - Added support for CAN Jaguar Sync Groups in RobotDrive
Unread 27-01-2015, 20:38
AKA: Jackson Taylor
My bad, I normally would have looked at that but I was in a bit of a hurry. That might explain the post being removed.
OK, so it supports the functionality but does not simply have a direct PWM jack like the SR. That's good to know, thank you. I'll look into these modifications and see if we want to move forward with that.
If not, would other controllers like Jaguars be able to be subbed in instead? If so, what would I need to do in code to allow this? If not, should I look into buying used SRs or just rely on FRC Pit Admin spares? It's a serious bummer (and odd decision IMO) that FIRST shipped a discontinued product in the KOP. I understand finding a use for old stock, but really, come on...
I'm using LabVIEW by the way. I'm going to look into using Java (or C++) later on.
Unread 27-01-2015, 20:56
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Talon SR vs SRX
Another option is the Victor SP. It is similar to the Talon SRX; both were jointly developed by Vex and Cross The Road Electronics. The Victor SP has a direct PWM input, but lacks the advanced capabilities associated with CAN that the Talon SRX has.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 27-01-2015, 23:16
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Talon SR vs SRX
I think either Talon SRX or Victor SP are good drop in replacements for Talon SR.
All three use the same output frequency (15.625KHz).
All three support PWM, though the SRX/SP have a common default pwm cal (1ms,1.5ms,2ms) but that's easily fixed by calibrating your pwm signal to better match your Talon SR (assuming you also calibrate your SRs). Basically if you always calibrate your motor controls, they should be close enough.
All three perform synchronous rectification.
All three support brake/coast select.
What's a fork connector?
Unread 27-01-2015, 23:18
ozrien's Avatar
Omar Zrien
AKA: Omar
Re: Talon SR vs SRX
One more - they all three have a 4% deadband.
Unread 27-01-2015, 23:38
NWChen's Avatar
Alum
Re: Talon SR vs SRX
One of these, which gets attached to a Victor 884/888, Talon SR, or Jaguar via the included screw terminals. Since the Victor SP/Talon SRX this year have wires builtin, these connectors no longer readily connect to either motor controller.
Unread 27-01-2015, 23:42
Re: Talon SR vs SRX
One of these...
I believe that's more commonly known as a spade lug.
Unread 27-01-2015, 23:48
Michael Hill's Avatar
Re: Talon SR vs SRX
The SRX also supports SPI, but I don't believe I've seen anywhere in the rules stating we can actually use it for motor control.
Unread 27-01-2015, 23:52
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Talon SR vs SRX
R59 says the Talon SRX must be controlled by CAN or PWM.
Unread 28-01-2015, 14:22
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
Re: Talon SR vs SRX
This is our teams first year to use Talons, in the past we have used Jaguars and Victors in combination. What are the major differences between Talons and Jaguars and Victors?
Unread 28-01-2015, 15:32
AKA: Jackson Taylor
Fans are optional, they are sealed so you don't need to worry about metal shavings "pollution", they have a choice of coast or brake mode set by a jumper, and they're smaller. That's my understanding.
