Go to Post I would like the game to be called Sanity. Just for irony's sake. - Keri Lynne [more]
Unread 28-01-2015, 00:50
kingcrazyt kingcrazyt is offline
FRC #0335
kingcrazyt is an unknown quantity at this point
Roborio freezing while deploying JRE
While I was trying to download the ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014 using the Java tool. It started to load and then it stops at the point when it begins to deploy the JRE to the roboRIo. I have re-imaged the roboRio twice and still it stops at that point. I don't know what else to do and was looking if anyone can help.
Unread 28-01-2015, 07:00
HolyHacker335 HolyHacker335 is offline
FRC #4945 (Titanium Wrecks)
Rookie Year: 2015
HolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud of
Re: Roborio freezing while deploying JRE
Did you update the roboRIO firmware first?
Unread 28-01-2015, 17:33
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
BrighidKHeh is an unknown quantity at this point
How do we update the firmware? We are having the same issue, although we keep freezing when the file is tarring.
Unread 28-01-2015, 18:03
You should already be familiar with the 2015 FRC Control System documentation on the ScreenSteps Live site. Simply follow the link to the instructions on Updating your roboRIO firmware.
Unread 30-01-2015, 19:30
You may be having the problem discussed in team update 2015-01-23.
