Go to Post If everyone else in the world is an idiot, you may need to recalibrate your idiotness scale. - GaryVoshol [more]
Unread 27-01-2015, 23:11
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
pic: Spectrum 3847 Public CAD Repository 2015
Unread 27-01-2015, 23:12
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Re: pic: Spectrum 3847 Public CAD Repository 2015
Once Again you guys never cease to amaze me! Great job guys and thanks for uploading your CAD during build season!
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 28-01-2015, 01:53
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thanks for releasing the CAD, it's amazing!
I was checking out your can grabber gearbo and saw you had a 12:42 reduction from the cim to a 2.5" wheel that drives the mechanism. Why did you opt for such a high reduction?
EDIT: Did you figure out the strength of the tape measure spring?
Unread 28-01-2015, 12:17
Engineering Coach
We haven't figured anything out about spring force, but I just a did the numbers quickly and at full speed I think that's ~18.7 fps. I don't think we will actually be able to use it at that speed. We'll probably have to slow the motor down more. Plus we have to pull the RC some what with that motor so we need the torque. Again as we stated none of this works (yet). We happen to have a bunch of the 42t pulleys so we figured we'd use them. The 12t is 3D printed. Hopefully we will be testing it this weekend.
Unread 28-01-2015, 20:22
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Ok. I put the numbers in JVN calc and it spat out 16.5fps free, 11.7fps loaded, but it loads at 37 amps at 8lb force. I guess it really depends on the load, as some measures will fall under their own weight even.
Unread 28-01-2015, 20:28
Engineering Coach
My guess is you were using the free speed of a CIM (~5,300) instead of a MiniCIM (~6,000).
- Allen
Unread 28-01-2015, 21:57
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
- Allen
Ah, I see! Whoops.
