Go to Post Indeed, the more ways you fail, the more ways you know something doesn't work.:) - Steven Sigley [more]
Unread 28-01-2015, 15:01
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: Sourcing an in-line chain tensioner
Just out of curiosity, have you experienced problems with turnbuckles in this application before?
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 28-01-2015, 16:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I assume you don't want this for wheels, since the tensioner would be unable to go past the sprockets.
We built our lift chain tensioners into the lift plate. We just bought some thumb screws, drilled holes big enough to pass the pin from a master link through it, and used the master link to connect the chain to a screw at each end. The lift plate has two holes which are in the same line, large enough to pass the threads through, and far enough apart so the screws can't meet. We used jam nuts to tension the chain and lock it down.
