Go to Post Begging, yelling, kicking, and screaming for members of my team to send me updates while I'm at college not doing homework. - Ginger Power [more]
Unread 28-01-2015, 17:26
TeamMagicSmoke's Avatar
TeamMagicSmoke TeamMagicSmoke is offline
AKA: The Entire Team
FRC #5259 (Magic Smoke)
TeamMagicSmoke is an unknown quantity at this point
Unhappy No Robot Code - Driver Station Error Code
I am the programmer from Team 5259 and we have spent the past few days completely stumped by and error code on the driver station. I have searched around and i cant seem to find what is causing the error. I tried uninstalling and re-installing everything. I even tried somethings that I found throughout the forum but I can't seem to find the exact error that we are experiencing.
Here is error code:
ERROR Unhandled exception instantiating robot org.usfirst.frc.team5259.robot.Robot java.lang.ClassNotFoundException: org.usfirst.frc.team5259.robot.Robot at [java.net.URLClassLoader$1.run(URLClassLoader.java: 372), java.net.URLClassLoader$1.run(URLClassLoader.java: 361), java.security.AccessController.doPrivileged(Native Method), java.net.URLClassLoader.findClass(URLClassLoader.j ava:360), java.lang.ClassLoader.loadClass(ClassLoader.java:4 24), sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:308), java.lang.ClassLoader.loadClass(ClassLoader.java:3 57), java.lang.Class.forName0(Native Method), java.lang.Class.forName(Class.java:259), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:197)]
Unread 28-01-2015, 18:30
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: No Robot Code - Driver Station Error Code
Is your RSL plugged in? We had a similar issue, and plugging it in fixed it.
Unread 28-01-2015, 20:08
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
This wouldn't fix any programming problem.
It appears that the roboRIO is attempting to load your main robot class but can't find it. Make sure that in your build.properties, package equals the the correct class to load. This happens when you change the name of your robot's main class because it doesn't know where to find it any more.
Unread 29-01-2015, 07:58
Is this correct, this is what I found in the build.properties file:
# Project specific information
package=org.usfirst.frc.team5259.robot
robot.class=${package}.Robot
simulation.world.file=/usr/share/frcsim/worlds/GearsBotDemo.world
I have been messing with the code for a while trying different things but i can not find the problem.
I tried deleting the program and re-writing it but I am still getting the same error
Unread 30-01-2015, 15:33
Thank you so much it took me a while but I found that it needed to be ".frc5259." not "frc.team5259".
Unread 03-02-2015, 21:46
Speckles04 Speckles04 is offline
FRC #2977 (Sir LancerBots)
Speckles04 is an unknown quantity at this point
Smile Re: No Robot Code - Driver Station Error Code
Actually, if none of these work, I found out tonight that there was a really dumb error. It was that I had instantiated a command in the robot class, which is made for only instantiating subsystems. Make sure that that is not your issue.
