Go to Post This wins this week's award for "Most Bizarre Thread". Carry on. - DonRotolo [more]
Unread 28-01-2015, 15:56
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Joystick issues
Ok so whenever we run the robot, the robot moves forward and backward if we move the joystick left and right, and if we move the joystick forward and backward, nothing happens. Here's our code
[IMG][/IMG]
[IMG][/IMG]
Unread 28-01-2015, 15:57
FRC #5005
Re: Joystick issues
Oh and we are using a y splitter for the PWM motors.
Unread 28-01-2015, 15:59
Re: Joystick issues
You have both motors wired to the x axis of a single joystick. The first output of Index Array unless overridden by an explicit index is Axis 0 or the x axis on a flight stick.
You probably want to use the normal y axis instead.
Either wire from the second output (y-axis), rather than the first output on the Index Array, or add a constant on the left side of both Index Arrays of "1"
Since you are only using one joystick, but using it for tank drive, your robot will only ever go forwards and backwards.
You don't have anything to turn.
It's more common to use two joysticks or at least two different sticks on an xBox-like controller to control the two sides separately.
If you want arcade drive, then you'll have to mix the x/y of the single joystick yourself, since you're avoiding 2 Motor Drive/Arcade.
Unread 28-01-2015, 16:24
FRC #5005
Re: Joystick issues
Is there a way to make it so that one joystick controls forward/back and the other joystick controls left/right?
Unread 28-01-2015, 16:25
Donjoe's Avatar
Donjoe Donjoe is offline
FRC #1610
Donjoe is an unknown quantity at this point
Re: Joystick issues
Everything Mark said, and just FYI, you don't need to keep calling the same joystick multiple times (the RefNum Registry Get and JoystickGetValues). You can just branch off the array wires and go to the other places you want to use the joystick...similar to how they branched off to send the values to the Smart Dashboard.
Unread 28-01-2015, 16:29
Re: Joystick issues
We call that Arcade drive.
You can look inside the Arcade drive vi to see what it does to mix the x and y of a single joystick in order to get it to turn.
Unread 28-01-2015, 16:33
FRC #5005
Re: Joystick issues
But we can't use an arcade drive vi with the single motor vi's can we?
Unread 28-01-2015, 16:38
FRC #5005
Re: Joystick issues
Like, the way I have it now, each joystick controls one set of wheels at a time, but never both at the same time.
Unread 28-01-2015, 16:46
FRC #5005
Re: Joystick issues
Man I just can't think of what to do here, every now and then when I change something the motors sound like a gear is loose and make this grinding noise, but other times they dont, but I dont see why I can't get this to work by having one joystick go forward/backward and the other handle left/right.
Unread 28-01-2015, 16:50
FRC #5005
Re: Joystick issues
Like here's what I have now
[IMG][/IMG]
Unread 28-01-2015, 17:15
FRC #5005
Re: Joystick issues
Ok now, and this makes no sense whatsoever, when I code it some ways, it sounds like gears are stripping in the motor, but sometimes it doesnt. Any ideas?
Unread 28-01-2015, 17:21
Re: Joystick issues
You cannot have more than one Motor Set Output per motor.
Your code is always giving conflicting orders to the motors.
One joystick is telling the motors to do one thing while the other joystick is contradicting those orders and telling them to do something completely different.
They are fighting each other.
I really suggest you try doing it the normal way until you understand a bit more about how motors work.
Unread 28-01-2015, 17:35
Re: Joystick issues
You're obviously thrashing around without a good idea of what the original robot program did or where you need to end up.
Stop.
Save your work and set it aside.
Start over with a fresh default robot project. Don't change anything except to make sure the Open 2 Motor Drive function is using the same PWM outputs the left and right motors are connected to. Invert either the left or the right motor if the robot doesn't drive forward when you push the joystick forward.
If you aren't able to make it drive properly by just defining those few things, ask for help again.
Only after you have the drive motors working the way you want them to should you start adding other things like additional motors, solenoids, etc.
Unread 28-01-2015, 18:08
FRC #5005
Re: Joystick issues
Stop.
Alright, well I can't test it until tomorrow, but would something like this work?
[IMG][/IMG]
Unread 28-01-2015, 18:22
Re: Joystick issues
...would something like this work?
I'm afraid not. You're still sending different commands to each motor in multiple places. You're "using" the Arcade Drive function in a completely inappropriate way. It won't run anyway, because you haven't given it the inputs it requires.
I'm serious -- it's going to be much, much easier to throw away what you have and start over than it would be to try to correct it. Really. Just make a new Arcade Drive robot project, make sure the left and right motors are defined with the proper PWM channels, and be prepared to invert the right motor (or perhaps the left motor, depending on your gearboxes).
