Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Unread 05-03-2003, 23:37
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 898's Robot
Unread 05-03-2003, 23:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
That is a very clean design. Your team sure stuck to the KISS principle. Those wings should be able to fend off other robots too. I can't tell but are the drill motors in there anywhere?
<edit>Those pneumatic cylinders look much longer than any 12 inches. What size are they?</edit>
Unread 06-03-2003, 01:26
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
Looks great. What kind of traction do you guys get with those belts?
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 06-03-2003, 07:48
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
I hope you have a good way of keeping those tracks in. When I was on 247 3 years ago we had a very similar tank system. If we were going full speed and took a turn too rough sometimes the treads own traction would pull itself out of the rollers. And when that happened.. it took a while to fix, it wasn't a problem that you could just drive the other way and it's fine again.
Other than that possibility, very nice, clean, well balanced design. (Less the compresser vs empty space). Just about everything is symmetric which is always helpful for operation. Less differences = Less Problems.
Very nice.
Unread 07-03-2003, 02:56
Billius Billius is offline
#0898 (Team Desert Storm)
Billius is an unknown quantity at this point
Thanks a lot! We totally stuck to the KISS principle this year and last. We didn't use drill motors anywhere on this bots, only CIM's. We get pretty good traction with the tread system (the metal grille fits nicley between the cogs). We haven't had too much of a problem keeping treads on, but we cut some of the flanges deeper just in case. We had some problems with the flange on the drive wheel coming off a lot, but that was nothing a little spot welding couldn't fix. I didn't order the cylinders, but I believe that they are 12" stroke and 1.5" or 1" bore (not sure though, another kid ordered the cylinders really early, before we even had an agreed on arm design. We just used what we had).
"Shop smart, shop S-mart"
pic: A Side View of Team 898's robot CD47-Bot Robot Showcase 2 07-03-2003 03:05
pic: TEAM # 123 - 2003 Robot for "King of the hill" CD47-Bot Robot Showcase 3 03-03-2003 08:56
Image Discuss: Team 159 Robot Pic 1 CD47-Bot Robot Showcase 2 17-02-2003 00:07
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
