Go to Post As Alice once said: "Curiouser and curiouser!" - Mike Betts [more]
Unread 28-01-2015, 17:55
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
NavX Field-Centric drive (LabView)
Hello,
I noticed, after playing with the NavX from KuaiLabs a bit, that the GetYaw has a range from -180 to +180. My teams is planning to use field-centric driving.
From a LabView perspective (using the Holonomic drive VI), will it take an input of -180 to +180? Also, how is the best way to "zero" the yaw? In other words, how can I let the robot which way North is (field-centrically)?
Also, I looked at this example: https://code.google.com/p/navx-mxp/w...dOrientedDrive And it doesn't look like they compensated for the -180 to +180 range at all (we just added 180 to the output to get a 0-360 range)
Thanks!
Unread 28-01-2015, 18:30
Re: NavX Field-Centric drive (LabView)
The Java WPILib code will. There's a good chance the LabVIEW will too.
It's a very simple vector rotation.
     * Rotate a vector in Cartesian space.
    protected static double[] rotateVector(double x, double y, double angle) {
        double cosA = Math.cos(angle * (3.14159 / 180.0));
        double sinA = Math.sin(angle * (3.14159 / 180.0));
        double out[] = new double[2];
        out[0] = x * cosA - y * sinA;
        out[1] = x * sinA + y * cosA;
        return out;
What's important is that the gyro angle is increasing in the clockwise direction.
Unread 28-01-2015, 19:00
jojoguy10's Avatar
AKA: Joe Kelly
        return out;
Right, inside the Holonomic VI, this calculation is going on. Will it handle negative inputs?
Unread 28-01-2015, 19:15
Sin(-pi/2) gives the same value as Sin(+3pi/2).
Same with Cosine.
Try it in Excel or on your calculator.
Or better yet, try it in a little LabVIEW program.
Unread 29-01-2015, 00:32
jojoguy10's Avatar
AKA: Joe Kelly
Same with Cosine.
Duh! You're right. We'll try it out next time.
