Go to Post What if my teams drive train isn't an option? - MARS_James [more]
Unread 28-01-2015, 17:39
Re: Mecanum Trouble
Swap them in Begin, making the inputs to the Open 4 Motor Drive match the actual motors on the robot.
Unread 28-01-2015, 18:15
Dawg2T4's Avatar
Dawg2T4 Dawg2T4 is offline
AKA: Chandler Douglas
FRC #3556 (GET SMART)
Dawg2T4 is an unknown quantity at this point
Re: Mecanum Trouble
Sending the robot a clockwise signal makes all of the wheels turn inward towards each other. When we made the change for the motor commands all it did was changed the strafing to the all in/out command and changed what we wanted the rotation to be to strafing.
- Chander, star of Frisbeez in the Trap
http://www.youtube.com/watch?v=3bM_Sv3xJ54
Unread 28-01-2015, 18:29
Dawg2T4's Avatar
Re: Mecanum Trouble
Here's a screenshot of our code, just to reiterate, this is the code that has forward, backward, and strafing correct but has a problem with rotating. When we try to rotate clockwise the robots wheels all run inward (meaning, the two front wheel go backward and the two back wheels go forward) and when we try to rotate counterclockwise the wheels go outward (the two front go forward and the two back go backward).
Begin
[IMG][/IMG]
Holonomic
[IMG][/IMG]
Teleop
[IMG][/IMG]
Unread 28-01-2015, 18:42
Re: Mecanum Trouble
If that's the case, the change you should have made, according to previous posts, is to swap the FrontLeft and BackRight motor commands. Is that what you did?
If not, undo what you did and make the correct change.
PS: you never did answer this post. It's important; it determines which motor commands should be swapped.
What he needs to do is swap the FrontRight and BackLeft motor commands (if the rotate clockwise command is causing the wheels to turn "outward") or swap the FrontLeft and BackRight motor commands (if the rotate clockwise command is causing the wheels to turn "inward").
If a rotate clockwise command causes all the wheels to run outward you need to swap the FrontRight and BackLeft motor commands.
If a rotate clockwise command causes all the wheels to run inward you need to swap the FrontLeft and BackRight motor commands.
Unread 28-01-2015, 19:40
Re: Mecanum Trouble
What change did you make?
Looks like the change was not done properly.
Please post LabVIEW png snippet of before & after code.
REDBARON's Avatar
REDBARON REDBARON is offline
AKA: Jack
FRC #3556 (Get Smart)
Rookie Year: 2015
REDBARON is an unknown quantity at this point
Re: Mecanum Trouble
Yes that is what we have done, we have tried it swapped and not swapped and neither ways work, when swapped if we give a pure clockwise command both sides run inward, sorry if I am repeating things, I just want to make sure everything is clear,
-Jack
Unread 28-01-2015, 19:56
REDBARON's Avatar
AKA: Jack
Rookie Year: 2015
Re: Mecanum Trouble
Before:
http://s278.photobucket.com/user/Daw...tml?sort=3&o=1
After:
http://s278.photobucket.com/user/Daw...tml?sort=3&o=0
Unread 28-01-2015, 20:12
Re: Mecanum Trouble
I don't know what change you made, but it didn't swap the suggested motor commands. The behavior described above is not consistent with the change suggested.
Swapping the FL&BR motor commands should have had no impact at all on the strafe command. And it should have corrected the rotate behavior.
This is assuming that you have provided accurate test data about wheel direction in response to fwd/rev and strafe left/right as shown in the attached chart.
Would you please post the before and after code as a LabVIEW PNG snippet as an attachment here on CD.
Unread 28-01-2015, 20:19
REDBARON's Avatar
AKA: Jack
Rookie Year: 2015
Re: Mecanum Trouble
Sorry, had some problem with posting the picture of the code. It's updated now with a link to each instance of the code.
Unread 28-01-2015, 20:24
REDBARON's Avatar
AKA: Jack
Rookie Year: 2015
Re: Mecanum Trouble
Strafing worked fine, it was during rotation (specifically clockwise) that both sides turned inward.
Unread 28-01-2015, 20:33
Re: Mecanum Trouble
Unread 28-01-2015, 20:38
REDBARON's Avatar
AKA: Jack
Rookie Year: 2015
Re: Mecanum Trouble
Here are the attachments, in order before and after.
Name:	Change Not Made.png
ID:	18033  Click image for larger version
Unread 28-01-2015, 20:45
REDBARON's Avatar
AKA: Jack
Rookie Year: 2015
Re: Mecanum Trouble
Sorry there was a miscommunication. With the motors FL & BR switched strafing and forward/backward work fine but rotation does not work, with them not switched, using rotation buttons causes strafing, and strafing fights itself.
The miscommunication was that the "change" in question was not clearly defined, as we had already left yesterday with that change made and the rotation still wasn't working. Sorry about that.
Unread 28-01-2015, 21:00
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Mecanum Trouble
Hold on a second, I think I know what's going on. On the "Open 4 Motor.vi", there are actually 4 terminals to invert motors. It looks like you have both of the bottom ones set to true and the top two unwired (which defaults to false). This would mean that Both your front left and front right motors are inverted, but not the other ones. Your inversions should match on sides, not front to back. I have attached a photo that should explain it a bit better.
Try going back to the default code (run the wires directly from the joystick axes to the holonomic vi) and see if inverting the correct motors fixes everything for you. If you push the joystick forward, and the robot moves backwards, switch the inversions to the right side instead.
I'm right 90% of the time, so why worry about the other 3%?
Unread 30-01-2015, 18:32
REDBARON's Avatar
AKA: Jack
Rookie Year: 2015
Re: Mecanum Trouble
We've sorted out the rotation problems by coding in a button that switches to arcade and using that to rotate, however we have noticed that strafing remains on the x-axis. but the y-axis causes rotation. we would like to resolve this and have the y-axis remain the same and the x-axis change
