Go to Post Well, I think it's awesome and the best thing ever. But I'm biased. ;) - OldDan1168 [more]
Unread 28-01-2015, 14:57
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Sourcing an in-line chain tensioner
My google searching skills may just be broken, but I can't find any kind of source to buy in-line chain tensioners from. I can find all sorts of side mounted tensioners but would really just prefer to use an inline one. If you aren't familiar, an in-line tensioner works similar to a turnbuckle but doesn't rely on rotation of the loaded end to apply tension.
If anyone could point me to a site (or even a certain hobby store) I would really appreciate it.
Unread 28-01-2015, 15:00
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Sourcing an in-line chain tensioner
Something like this from Team 221 Robotic Systems might work for you.
Unread 28-01-2015, 15:01
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Just out of curiosity, have you experienced problems with turnbuckles in this application before?
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 28-01-2015, 16:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I assume you don't want this for wheels, since the tensioner would be unable to go past the sprockets.
We built our lift chain tensioners into the lift plate. We just bought some thumb screws, drilled holes big enough to pass the pin from a master link through it, and used the master link to connect the chain to a screw at each end. The lift plate has two holes which are in the same line, large enough to pass the threads through, and far enough apart so the screws can't meet. We used jam nuts to tension the chain and lock it down.
Unread 28-01-2015, 21:05
Monochron's Avatar
Engineering Mentor
There we go, that is exactly what I was imagining. We are using #35 chain, but I imagine we could just widen the mounting holes to use #8 bolts. Thanks!
Unread 28-01-2015, 21:19
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
Misumi also sells them.
Turnbuckles for Chain
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 29-01-2015, 09:21
Knufire Knufire is offline
See the note that it's only recommended for light duty applications. I believe it was designed for steering chains on a swerve/crab drive. You could PM Anthony Lapp and ask him for his opinon.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 29-01-2015, 09:32
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
We put together a rough sketch with a turnbuckle from mcmaster and a couple aluminum L-brackets for mounting to our elevator lift carriage.
http://2015.discobots.org/node/16
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
