Go to Post but who knows what you might want to try next? - dlavery [more]
  #46   Spotlight this post!
Unread 29-01-2015, 09:44
Cryptogenic Cryptogenic is offline
Cryptogenic is an unknown quantity at this point
Re: Eclipse won't connect to roboRIO
Originally Posted by Alan Anderson View Post
Were the computers upgraded to 8.1 after the programming tools were installed? Perhaps the upgrade modified a path setting, or replaced a .dll file, or moved a folder. Has anyone tried uninstalling and reinstalling Eclipse and the plugins after doing the upgrade?
I tried doing this. It was actually one of the first things I did. It didn't change anything. I think that some files need some drivers or something similar that isn't supported when you upgrade your computer to 8.1.
  #47   Spotlight this post!
Unread 29-01-2015, 11:53
TheMechanic40 TheMechanic40 is offline
FRC #3506 (YETI Robotics)
TheMechanic40 is an unknown quantity at this point
Originally Posted by Cryptogenic View Post
Did the computer start with 8.1? The computers that we tested on were originally 8 and upgraded to 8.1 are the ones that don't work. We don't have any computers that were originally 8.1 to test it on.
My computer came with windows 8.1, but I'm not sure about the others. One person has a surface so I assume it started with it and I know she can use mDNS because we have to use it to install java to the roboRIO. Although, the members that have Windows 7 can't use mDNS, but can upload code using the IPv4 address 10.35.6.2
  #48   Spotlight this post!
Unread 14-02-2015, 10:29
Lightbulb Re: Eclipse won't connect to roboRIO
There was an NI update. So I downloaded that yesterday, and hopefully it will work today. I will find out when I get to the lab, and I will post the outcome.
  #49   Spotlight this post!
Unread 14-02-2015, 11:39
I downloaded the update and just tried to deploy code to the roboRIO, but still I get the same error: BUILD FAILED
C:\Users\Sam\wpilib\java\current\ant\build.xml:45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
  #50   Spotlight this post!
Unread 15-02-2015, 14:53
So turns out is in the Windows Firewall. But not in such an obvious spot. Click the <windows> key, then search for "Windows Firewall" and click on windows firewall with advanced security on Local Computer.
https://drive.google.com/open?id=0B3...ZVE&authuser=0
Then, in the domain section, you have to change inbound to allow.
https://drive.google.com/open?id=0B3...aWs&authuser=0
Then save everything and it will compile It worked on mine
  #51   Spotlight this post!
Unread 15-02-2015, 16:02
I'm not exactly sure what you're saying because I need permission to view the links you have provided.
  #52   Spotlight this post!
Unread 17-02-2015, 00:34
I fixed the links. The first link is:
https://drive.google.com/file/d/0B3z...ew?usp=sharing
The second link is:
  #53   Spotlight this post!
Unread 17-02-2015, 00:37
Thank you, I will post my results as soon as I can.
  #54   Spotlight this post!
Unread 17-02-2015, 18:32
Unfortunately, I still can't deploy code despite me changing the firewall settings.
  #55   Spotlight this post!
Unread 17-02-2015, 18:53
Cyan's Avatar
Cyan Cyan is offline
Vegeta SSJ4
AKA: Sayan Dutta
FRC #2642 (Pitt Pirates)
Cyan is an unknown quantity at this point
I think my team used to have a similar problem. Re-imaging the roboRIO worked for us. You said that you imaged it, but have you tried re-imaging?
Also, you might want to check under "Eclipse > Window > Preferences > Java > Installed JREs" and make sure you have the JDK selected instead of the JRE. I think that this also caused this problem for one of our teammates.
  #56   Spotlight this post!
Unread 18-02-2015, 00:54
And you should also check, in the Preferences section for the WPILIB section and make sure you have the team number. My computer did not make it pop up and never asked me to set my team number, it would just fail to deploy.
  #57   Spotlight this post!
Unread 18-02-2015, 00:55
We have checked everything it told to check in the console.
