Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 29-01-2015, 10:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Help Calculating time to recharge air tanks
Originally Posted by pfreivald View Post
Okay, I think I've got it. Integrate the curve between the pressures whose charge time you want, set that equal to the difference in energy of the gas (delta-P*V) over time, and solve for time.
Yes?
(Man, I need a nap.)
This is what I would do. Even this is slightly optimistic as the air will cool off as it flows into, and sits in, the storage tanks. Accurately modeling the compressors performance will be a bit more than trivial.
A decent sanity check would be to take the compressors electrical power input, multiply by a conservative assumption of efficiency, and divide the difference in stored energy by this power to get time.
OP - your initial approach makes too many optimistic assumptions such as no temperature change, constant flow rate vs pressure, etc.
