Go to Post Part of the magic of FIRST is the interaction between different teams- and that becomes clear as day as the clock starts ticking. - mhayon [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 29-01-2015, 12:07
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
Re: Network Switch
Originally Posted by aryker View Post
It's generally never a good idea to place your electronics on moving parts--do you mind going into a little more detail about that?
As a general rule, I definitely agree and we avoid it when we can.
Their are a few reasons why we chose to put processors on moving parts. The moving ones are on our elevator carriages. We are using them to get the absolute position of the elevator. The frame of our elevator has an overlay on it that has a gray code binary system encoded on it. We are then using reflective photo interrupters to read the encoded binary. We are encoding 10 bit numbers meaning we need 10 photo interrupters, each with 4 wires (2 for LED, 2 for photo diode). Rather than running 40 wires to our belly pan and doing the decoding there, we are using an arduino to convert the data into a decimal number on the carriage then sending that to our main controller.
We decided it was better to put the processor on the carriage and have a communication cable running through our cable carrier than to run 40 cables and put the processor on the belly pan.
