pneumatic tubing swelling
http://imgur.com/MLbRg18
We have this piece of tubing going from the compressor to a T-fitting. We noticed last night that it had swollen and had it replaced. The new one has now swollen. Our system isn't going above 115 psi, so I don't think the pressure is an issue. Does anyone have any ideas, or experience with a similar problem? |
Re: pneumatic tubing swelling
I suppose. If the tubing is touching the compressor anywhere it would be on the opposite side of where the heatsink is. I didn't think that part of the compressor got very hot, but I could be wrong.
We used a computer fan to blow air across our compressor last year and it kept it nice and cool all season. Before this it was getting extremely hot.
If so, I would recommend adding some metal fittings before the plastic tubing to dissipate heat from the hot air coming out of the compressor. Placing one of the large fans from the KoP next to the compressor will also help. |
I'll confirm the suggestion to add a fan, blowing across the compressor, to solve this problem. The duty cycle of the compressor is only 9%, which means you need to let it cool for eleven times as long as you run it. This time of year, we typically are working on the robot, and testing stuff...running it for five minutes at a time is typical, and doing this will over heat the compressor, unless you add active cooling. It doesn't take much to keep it cool, one of those square fans at least 100mm across should do it.
#7
Air leaving the compressor is hot because it is compressed rapidly without much time to transfer heat to the surrounding environment. By adding the valve (or additional metal fittings if you already have the valve in place), you give the air more time to cool off before it reaches the plastic tubing. |
#9
Not only does the compressor get hot from the friction of the piston but the Ideal Gas Law states that increasing the pressure of a gas increases its temperature. The compressed air from the compressor is actually hotter than ambient. If you run it for a long time it would be conceivable that the tube gets heated by the compressed air to a point where it can no longer withstand its designed working pressure and you see the bubbling that you showed.
A short metal pipe attached to the compressor would help to dissipate this heat. Or let your system coll a bit in between runs. EDIT: looks like John beat me to it ![]() |
#10
There are a few metal fitting before the tubing is attached. We'll see about mounting a fan to cool it this evening.
Thanks everyone. |
#11
-Ronnie |
#12
I would not be concerned about the zip ties melting. A quick Google search shows that most zip ties are made out of Nylon 6-6, which has a melting point of ~500° F. Even if the fan somehow fails, I don't think the compressor will get anywhere near that hot.
#13
lol. Thank you, will stick with simplicity and stay with the zip ties.-Ronnie |
#14
More speculative answers: the tube you have may not be rated for the pressure you're using (not likely, but worth checking) or could be old and have lost some of its stiffness if stored improperly for an extended period of time. [edit: bah, took too long to write and missed the discussion!] Last edited by MechEng83 : 29-01-2015 at 13:10. Reason: long post writing duration |
#15
Keep in mind that there are other legal compressors, too! The commonly used Viair compressor has a bigger brother in their industrial grade line. It has a cfm below 1.05, which makes it legal to use, and has a much bigger thermal mass. This allows it to be rated for continuous use, not just the 9% of the normal Viair teams use. It also comes with a steel mesh leader hose - this is considered part of the compressor (per last year's Q &A, at least... I haven't seen it asked this year yet), and can be used to help ensure the tubing is well away from the hot parts of the compressor!
