Go to Post JVN, thanks for working with me. You will make a great MC anywhere. Folks, he actually loosened up and fit right in. - Steve W [more]
Unread 29-01-2015, 17:46
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Adding a sensor reading to the dashboard
How would I add a numeric indicator to the dashboard that would read the distance from an ultrasonic sensor? I can program the sensor itself I just have no idea how to make a visible reading for it.
Unread 29-01-2015, 18:07
FRC #5005
Re: Adding a sensor reading to the dashboard
Or do I even have to change/add anything for the dashboard? If I don't I think I figured out how it works
Unread 29-01-2015, 19:38
The default project has examples in Teleop.vi
These are all writes that are sending values to the Dashboard.
  • RobotDrive Motors
  • Joystick 1/Axes
  • Joystick 1/Buttons
  • Joystick 2/Axes
  • Joystick 2/ Buttons
Unread 31-01-2015, 11:49
FRC #5005
Exclamation Re: Adding a sensor reading to the dashboard
  • RobotDrive Motors
  • Joystick 1/Axes
  • Joystick 2/Axes
Ok but how would I make, like an ultrasonic sensor appear on the dashboard, I've been trying to make it work with a custom dashboard but I have no idea what I'm doing on the custom dashboard, any ideas?
Unread 31-01-2015, 12:14
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Use SD Write Value to send the value to the dashboard. It will show up under the Variables tab without having to change it. If you want it displayed, create an indicator with the same name as you gave the SD Write Value.
Unread 31-01-2015, 12:19
Here's an example:
The left screenshot is of Periodic Tasks in the default robot code.
The right screenshot is of the default Dashboard front panel and block diagram.
ID:	18071  Click image for larger version
Unread 31-01-2015, 12:35
FRC #5005
Awesome! Thank you both very much!
Unread 31-01-2015, 12:52
FRC #5005
Here's an example:
Actually wait, how would I wire the indicator in the custom dashboard?
Unread 31-01-2015, 12:58
No wiring is actually required.
Just the name has to exactly match.
You can see "My Number" on the bottom right of the Dashboard block diagram and that's all that is needed.
If you want to, you can explicitly read the value (just the opposite of the Write) and wire the read to the indicator.
Unread 31-01-2015, 13:01
FRC #5005
But in the dashboard, whenever I create an indicator in the custom tab, it makes it in the VI's of the custom dashboard and gives me an error unless I wire it to a control, or am I just doing this completely wrong?
Unread 31-01-2015, 13:02
FRC #5005
Wait, nevermind, I might be the stupidest person to attempt to program in labview, I was getting a different error and I thought it related to that, so nevermind, thank you so much for the help!!!
