Go to Post Making even just one person feel safe and included in FIRST is how we know that we have succeeded. - Mr_Moko [more]
Unread 29-01-2015, 18:51
blincoln1534@gm's Avatar
blincoln1534@gm blincoln1534@gm is offline
Billy Lincoln
FRC #5000 (The Hammerheads)
blincoln1534@gm is an unknown quantity at this point
Pneumatic Piston using Labview will not fire
Here's our dilemma,
We have 1 double solenoid powering 2 pneumatic pistons. The toggle for them firing is supposed to be a single button (the trigger aka button 1) on the joystick. However, when he hit the button nothing happens. The extend side of the solenoid is connected to the 0 port on the PCM and the retract side of the solenoid is connected to the 1 port on the PCM. The joystick for this system is connected to USB 1. I have attached our code thus far. Let me know if I can answer any questions.
I have tried several sites, but cannot figure out what is wrong. Thanks!
Unread 29-01-2015, 19:23
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Pneumatic Piston using Labview will not fire
Is the PCM voltage jumper set to the same voltage as your solenoids?
We tried running 24 volt solenoids at 12 volts and they just didn't work.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 29-01-2015, 19:25
Billy Lincoln
yes, both the solenoid and the PCM are set to 12v
Unread 29-01-2015, 19:29
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
Are the red lights on the PCM lighting up next to the channel's connectors?
Sleep? What is that? A rare Pokemon?
Unread 29-01-2015, 19:31
AKA: Roger Moore
In begin.vi you have the solenoids are set as 1 and 2 NOT 0 and 1. That is likely your problem.
Stronghold
Student 2013-2016
Unread 29-01-2015, 19:39
Billy Lincoln
nope both lights are green
@orangemoore Let me see if that fixes our problem
Unread 29-01-2015, 19:42
Billy Lincoln
now that i examine it further, there is a red light on the side of our PCM for port 1...But not for port 0...
Unread 29-01-2015, 20:37
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Can you write code to do the following:
1) Display the value of Button 1 (or whatever button you are using) on your smart dashboard. Print "pressed" when it is pressed, and "not pressed" when it is not pressed.
2) Send a signal to extend the pneumatic. Wait 1 second. Send a signal to retract the pneumatic. Wait 1 second. Repeat.
What are your results for #1? Does it display the status of the button correctly?
What are your results for #2? Does the pneumatic extend and retract?
Unread 29-01-2015, 22:00
Billy Lincoln
We're using Labview so we are not familiar with the java/c++ smartdashboard...However on the labview dashboard, when we press several buttons, there is a response from each of the buttons on both joysticks...I think either our begin.vi is corrupt or our teleop.vi is corrupt because only 1 red light shows up on our PCM and that is for port 1...
Unread 29-01-2015, 22:48
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
You don't need to use SmartDashboard to run a simple button test. Just add a boolean push button to your front panel and wire it into a case structure on the block diagram. Boom. True/false statement triggered by a push button.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 29-01-2015, 23:06
Then for part 2:
Can you drive the pneumatics directly in the code?
Unread 30-01-2015, 10:18
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Here's our dilemma,
We recently had this problem. Just to make sure, is the solenoid under PRESSURE while you're trying to switch? We spent about 40 minutes with this issue and we tried hooking up our compressor system to it and it switched perfectly.
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 30-01-2015, 12:49
Billy Lincoln
I changed our code and added a case structure, I will test when I get to the workshop later and let you know.
Yes, the compressor is already hooked up to our system and running fine...If it helps with the troubleshooting, we can manually fire and retract the cylinders using the push buttons on the solenoid if the power to the robot/solenoid is off.
Unread 30-01-2015, 15:03
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
So it sounds like the solenoid output is activated by the PCM if the side RED LEDs are turning on. To be clear I mean the LEDs mentioned in Section 3.2 of the PCM's user guide.
If a solenoid channel's output LED is illuminated red, then there should be Vsol measured across the red and black output of that channel's weidumuller pair.
Vsol will be approx battery voltage if the PCM jumper is in 12V mode.
Vsol will be 24V if jumper is in 24V mode or not present.
So use a voltmeter to measure the voltage leaving the PCM going into the solenoid harness. If the PCM is giving your 24V solenoid 24volts, then no amount of software is going to fix your problem, the issue is downstream and is likely the solenoid harness (happens to me once in a while) or just a bad solenoid.
Unread 30-01-2015, 18:43
Billy Lincoln
Adding a case structure did it! Thank you to everyone for their help!
