Go to Post A great mentor guides without giving the answers, teaches through discovery, demonstrates without lecturing, provides support from backstage, observes without hovering, and leads by example. - dlavery [more]
Unread 29-01-2015, 20:19
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Drift on ADXRS453 Gyro
Our team has been trying to use the ADXRS453 gyro (datasheet), with this board (http://www.digikey.com/product-detai...53Z-ND/2700448.
We got SPI communication working pretty well, we think. We're getting data from the gyro, in the format we expect. But while at rest, the sensor returns apparently random values between ~0.3 and ~0.8, averaging around 0.6. We tried using a calibration routine, which samples the rate while at rest to find an average drift, but the amount of the drift seems to vary depending on how fast the gyro is rotating, with the result that even with the calibration the gyro results are not usable.
We're displaying the raw 1's and 0's from the gyro on the SmartDashboard, and they show the drift, so we can be pretty certain the issue doesn't have to do with how we process the data. The status bits always indicate "valid sensor data." Our code on github (relevant files ADXRS450Gyro.h and ADXRS450Gyro.cpp) if you want to look at that.
Does anyone have any idea how either to fix this, or to compensate for it? As it is we can't really use the gyro for anything. The ADXRS453 is supposed to be a fairly precise gyro, so I assume that there's a way to get useful data from it. Any ideas?
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
