Go to Post Do you think Pizton's Lard would want to be a FIRST supplier and give every team some lard in the KoP? We could grease our gearboxes with it and every finals match could smell like bacon. - Ty Tremblay [more]
Unread 29-01-2015, 20:37
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Pneumatic Piston using Labview will not fire
Can you write code to do the following:
1) Display the value of Button 1 (or whatever button you are using) on your smart dashboard. Print "pressed" when it is pressed, and "not pressed" when it is not pressed.
2) Send a signal to extend the pneumatic. Wait 1 second. Send a signal to retract the pneumatic. Wait 1 second. Repeat.
What are your results for #1? Does it display the status of the button correctly?
What are your results for #2? Does the pneumatic extend and retract?
