Go to Post It's cool when good things happen to good people. :) - Rich Kressly [more]
Unread 29-01-2015, 20:50
Dr3wj0n3s Dr3wj0n3s is offline
FRC #0308
Dr3wj0n3s is an unknown quantity at this point
Cool Charging Batteries on their side
I'm designing a battery charging stand and one possible design involves the batteries being stored and charged horizontally. Is there any disadvantages or possibilities of the battery being damaged or the cells inside being damaged? thank you for your help.
Unread 29-01-2015, 20:53
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Charging Batteries on their side
Robot batteries need to be charged vertically to properly vent the gases that are a byproduct of the charging process.
Unread 29-01-2015, 21:20
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Dont charge them upside down, but they don't have to be perfectly vertical. They are fine to charge on their side but they won't vent as efficiently. As long as you don't charge them at too high a rate they will be just fine. Lots of wheelchairs have their batteries on their side and they charge all of the time in people's houses with no issues.
Our batteries charge at a 45 degree angle at 2 amps and have never been a problem in over a year of charging and maintenance.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 29-01-2015, 22:00
BenjaminKrawiec's Avatar
BenjaminKrawiec BenjaminKrawiec is offline
FRC #0308 (Monsters)
Rookie Year: 2015
BenjaminKrawiec is an unknown quantity at this point
Hi Drew!
Unread 29-01-2015, 22:21
AdamHeard's Avatar
Lead Mentor
Source please.
Unread 29-01-2015, 22:31
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
One of our servers ups has one of the batteries mounted upside down. Same style of battery that powers our robots. I am supersticous. We charge our batteries up right.
Unread 29-01-2015, 22:45
cgmv123's Avatar
AKA: Max Vrany
Source please.
http://www.chiefdelphi.com/forums/sh...33&postcount=9
http://www.chiefdelphi.com/forums/sh...60&postcount=8
http://www.chiefdelphi.com/forums/sh...7&postcount=11
http://www.chiefdelphi.com/forums/sh...62&postcount=7
Unread 30-01-2015, 00:20
AdamHeard's Avatar
Lead Mentor
None of that is sourced...
Please, someone show an actual technical source for the specific batteries we use.
Unread 30-01-2015, 00:36
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
FRC legal batteries are sealed to allow for use in any orientation. If we were only allowed to charge upright, wouldn't we have to place batteries in the robot upright too?
However, we brought this up to our battery distributor. Their advice was to store batteries upright if they were being left for a long period of time. While it is a 'sealed' battery, it will leak if inverted or left on its side for too long.
TL;DR.... It doesn't really matter unless you leave your batteries in inverted or on a side for a long period of time.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 30-01-2015, 00:46
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
The quote in the first link has a direct link to enersys. Am I missing something?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 30-01-2015, 00:51
AdamHeard's Avatar
Lead Mentor
Yup.
That says don't charge with a battery upside down, which we all seem to agree on.
He was stating you must charge vertical, which is different. A battery can be nonvertical and not be upside down.
I admit I haven't done much searching myself, but I'm not the one making the often repeated claim that they must be charged vertical.
Unread 30-01-2015, 10:52
robochick1319's Avatar
robochick1319 robochick1319 is offline
Robochick1319
AKA: Catherine
FRC #1319 (Flash)
robochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond repute
http://www.cdtechno.com/pdf/ref/41_6739_0112.pdf
http://www.apcmedia.com/salestools/S...f?sdirect=true
http://www.gpbatteryygn.com/products/vrla/ States that VRLA batteries "can be operated in virtually any position (except upside-down)."
http://www.mkbattery.com/documents/5548MK-SLA-MSDS-2009.pdf
MSDS
Here are some interesting reads regarding batteries and their ventilation. I think we may have some confusion regarding what kind of battery we are using. I believe it is a valve regulated battery which mean that ventilation is necessary but charging it on it's side with proper ventilation should be fine.
I may be wrong but that's what I have gathered so far. We charge ours upright because it's just easier. They get proper ventilation (no worries there) and are easier to access.
17 x UL Industrial Safety Award Winner (2005 - 2015)
2015 Curie Division Industrial Safety Award sponsored by Underwriters Laboratories
2015 Georgia Southern Classic Champion
2010 Palmetto Regional Engineering Inspiration Award Winner
2008 Peachtree Regional Champion
2007 Galileo Division Champion
2007 Palmetto Regional Champion
2006 Boilermaker Regional Champion
Unread 30-01-2015, 11:15
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The valve on VRLA should never open under normal conditions. The ventilation requirement is they because they can discharge hydrogen if they are overcharged & is a safety precaution.
