Go to Post Aim for the stars – you just might hit a planet. - Leo M [more]
Unread 28-01-2015, 19:21
Blindpoker Blindpoker is offline
-Commander of the COU-88
AKA: Ross Thomas
FRC #1785 (Robocats)
Blindpoker is an unknown quantity at this point
Quick Question Regarding 2015 FRC Rules
Me and my team were considering putting a laser-grid or outline on the back of our robot using some simple guided LED's or something of the sort. We just wanted to see if it was legal before doing so.
~this is my signature, look at it shine
Unread 28-01-2015, 20:05
Re: Quick Question Regarding 2015 FRC Rules
The first question I have is, did YOU find any rules against it? Or Q&As?
If not, then it's quite probably legal, if done right. That "done right" is the hard part.
Lasers: Any laser more powerful than Class 1 would be ruled illegal by the inspectors (R8). But, you're looking at LEDs instead, so I suggest looking at the Custom Circuit rules.
Which latter items indicate that you'd be legal if you didn't violate R8's rules on interfering with other robots, or the various rules on power sources and voltages found in Section 4.8.
Unread 29-01-2015, 10:35
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Do you mean putting some type of target on the back of your robot, and using a range finder of some sort from the Driver's Station in order to get field relative positioning information?
Unread 29-01-2015, 12:05
AKA: Ross Thomas
What I mean by it is;
Like in a Sedan or Mini-Van with a rear-view cam, you have on the screen a laser outline to help you back into spots, so why not just use some laser pointers or a shaped LED grid to guide your lifter or claw to the tote/bin.
Unread 29-01-2015, 12:25
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Note that most laser pointers are class 2 lasers and hence are not legal on a robot. I don't know how bright a class 1 laser would be for this application. I could see a narrow beam flashlight being used to help center a bot on a game piece.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 29-01-2015, 13:02
I think the outline is drawn on the screen, and not actually projected. But, I get your point.
I think you are better off with a projected non-laser light, rather than a laser.
In prior years, we put a clear plastic over the screen, and drew lines over the video image.
Unread 29-01-2015, 13:22
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Most rearview cameras have screen projection, and not actual physical projection. You could do this in camera code.
College sux yo
Unread 29-01-2015, 20:54
Although, for this application, a physical projection might be more useful. For example, by lighting up the tote when it's in range for picking up.
Class 1 lasers are plenty bright. I would actually say that MORE laser pointers are Class 1 than Class 2, because Class 1 is generally considered "eye-safe" (or at least, as "eye-safe" as a laser can get!).
That being said... Take an old stage trick, and use a flashlight with a mask on it so that it only shows light where you want it. Use a powerful flashlight, powered by the robot's main battery, maybe use a filter to color the light, and cut a mask (or a barn-door system of panels) to get the light to fall exactly where you want it.
