Go to Post FIRST is an amazing combination of principles that, when applied to the world, has had a monstrous effect on the way High School students learn, think, and relate to others. - Amanda M [more]
Unread 29-01-2015, 16:30
TeamMarcies TeamMarcies is offline
FRC #4777
TeamMarcies is an unknown quantity at this point
Issues with the Gyro - Help
Hey!
We've been trying for hours to fix the issue with our Gyro and we're not sure whether it's a software issue or hardware issue.
Here is our wiring (i only posted links since they are huge images):
http://i.imgur.com/ChcTKaV.jpg
http://i.imgur.com/6MXDKSq.jpg
As we rotate our gyro, we're expecting the gyro pointer to move but it isn't:
http://puu.sh/fcJgn/209d7ff45f.jpg (when we are connected to joystick/communication/code)
This is our code snippet for the gyro to drive forward straight and to drive backwards straight.
Btw, the gyro.reset(); is already called before this thread starts.
        public double gyroSensitivity = 0.05; // (voltage / 1000)
	public void run() { // This method is executed only for DriveForward and
						// DriveBackward
		r.autonomousCounter = 0;
		r.theRobot.setExpiration(0.1);
		while ((Math.floor(r.autonomousCounter / r.loopsPerSecond)) <= DriveClass.seconds) {
			if (RecycleRush.InTeleop) {
				break;
			if (forward) {
				r.theRobot.drive(r.robotDriveSpeed, -r.gyro.getAngle() * r.gyroSensitivity);
			} else if (!forward) {
				r.theRobot.drive(-r.robotDriveSpeed, -r.gyro.getAngle() * r.gyroSensitivity);
			Timer.delay(r.timerDelay);
		r.theRobot.drive(0.0, 0.0);
It drives forward, but does not drive complete straight - same for backwards.
We also made code to make it rotate while its stationary.... We made two methods, one of which we deprecated for now because we found simpler logic.
	public void DriveRotate(int rotateAngle) {
		r.queueThread(new Runnable() {
			public void run() {
				r.gyro.reset();
				while (r.gyro.getAngle() < rotateAngle) {
					r.theRobot.drive(0.0, 1);
	/* DEPRACATED METHOD
			public void run() {
				r.gyro.reset();
				double angleHeader = r.gyro.getAngle(); // Initial Angle
				while (Math.abs(angleHeader - r.gyro.getAngle()) <= Math.abs(rotateAngle)) { // Rotating
					r.theRobot.drive(0.0, rotateAngle * r.gyroRotationSpeed);
					DriverStation.reportError(r.gyro.getAngle() + "", true);
We have the Gyro connected to: 0 so this is our declaration:
    // Gyro - Handles Trajectory Paths
    public int GyroChannel = 0;
    public Gyro gyro = new Gyro(GyroChannel);
Basically, the Gyro isn't working in any way.
Unread 29-01-2015, 23:18
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: Issues with the Gyro - Help
Originally Posted by TeamMarcies View Post
Hey!
						// DriveBackward
				break;
			if (forward) {
			public void run() {
				r.gyro.reset();
			public void run() {
				r.gyro.reset();
Where are your signal wires? is it the red/black wire that's sideways? id recommend using pwm wire. but anyways, can you preform an analog read on the rate pin and post your results?
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
Unread 30-01-2015, 20:48
FRC #4777
Just reporting back in to say we have resolved the situation! Thanks for the help!
Unread 31-01-2015, 10:50
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
If you don't mind, could you post how you solved the problem? I was having similar issues.
Unread 03-02-2015, 02:51
carrud carrud is offline
AKA: Clark Rudder
FRC #2637
carrud is an unknown quantity at this point
yes, please tell us how you resolved this!!!
