Go to Post Earlier this week it took me a little bit too long to realize that the reason my pen wasn't writing correctly was that it was actually a screwdriver. I'm going to have to ask for a few nights of honest sleep before signing off on a report. - EricVanWyk [more]
Unread 30-01-2015, 01:06
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Too much grease?
What transmissions? With the ones included with the KOP chassis you'll have to really work at over greasing them. There is a lot of open space in them and the excess grease will be thrown out of the way. Now if you packed the cavity by using say 4 or 5 packets of the size that they give you per trans then yea you'll end up with drag and the transmission heating up. Use 1 full packet per gear box and you'll be fine.
Now if you are talking a Versaplantary then it would be easy to over grease.
Unread 30-01-2015, 08:31
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Versa planetaries run hot at higher speeds and loads, greased or not. However, it's never caused us a problem.
We really need to know the type of gearbox in question.
Unread 30-01-2015, 13:23
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
We are using 2 versaplanateries which we set up yesterday with 3:1 ratio and attached the cim motor to.
We had shortened the output shaft of the cim and then added grease to the gears and then some.(we have a tube of grease which we just stuck out hand into and smeared on the gears and inside the housing after closing it up)
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
