Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Unread 24-01-2015, 20:14
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Team 95 Hard At Work - 2015
Assembly progressed reasonably well with the robot's chassis.
An inside view of one of the drive pods. I was pleased to learn that a 10-32 Riv-Nut flange does a good job of locating the 7/16 hex sockets in a Vex transmission.
You can almost see the outboard bearing in this picture.
Arm pivot posts and fixed sprockets were installed.
Again, liberal use of Riv-Nuts, though they are difficult to installed near their maximum rated material thickness.
And at least one of the arm shoulder motors was installed.
Unread 24-01-2015, 20:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
A number of other parts were made and/or futzed with.
Unread 25-01-2015, 03:49
Professional Stat Padder
Some of that aluminum looks really thick for a game with no defense.
And what kind of arm are you running?
Looks great so far, guys. Keep up the good work!
(2015-Present)
Unread 25-01-2015, 07:49
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
The main chassis plates are #10awg sheet metal, 0.100in. It is probably a little overkill for this year, but on the other hand we get the material for free and we were able to remove a lot of it for lightening, "trussing it out" as we say. Other 'major' parts, like the belly-pan and deck, are being made noticeably lighter than last year.
We've designed a 4-bar linkage arm with a little more than 180deg of total travel. It will be counter-balanced by two air cylinders and drive by two CIMs + 50:1 Versa planetaries + 16:60 sprocket reduciton.
Also, some over-all chassis pictures finally got uploaded. Around 47lbs as she sits currently.
Unread 29-01-2015, 08:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
We've been keeping the mills busy:
And throwing our fair share of money at VexPro:
So many prototypes....
Unread 29-01-2015, 08:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
The chassis is coming together though!
And so are some other assemblies.
Unread 29-01-2015, 08:51
GortGortGort's Avatar
GortGortGort GortGortGort is offline
AKA: Lee Cole - Mentor
FRC #5040 (The BoltBots)
GortGortGort has a spectacular aura aboutGortGortGort has a spectacular aura about
Wow love you design of your base and that great shop too. Good Job.
Unread 29-01-2015, 09:52
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Thanks!
Unread 29-01-2015, 12:26
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
I love this thread and your designs. Just curious, why a cim and mini cim per wheel? On your hinged mechanism, how did you get that bend in the back off the pivot???
-Ronnie
EDIT: After looking further, It looks like you might of cut that piece that curves around the axel.. I thought it was all one which made my jaw drop.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 29-01-2015, 15:05
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
-Ronnie
Thanks! We appreciate the kind words!
We figured more power, better drivetrain! I think the CIM+miniCIM might wind up being a little overkill, but I'd rather be stripping weight out then adding it in later, so we planned optimistically for an 8-motor drive.
The gripper mechanism is just a piece of #10awg 5xxx al sheet bent into a c-channel with an OTS hinge from mcmaster bolted to it with some drilled holes and PEM nuts.
Unread 29-01-2015, 18:25
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Lookin' very sweet; can't wait to see the finished product! Wish I was available Week Zero... :-/
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 29-01-2015, 18:30
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Thanks, me neither! We're off to Suffield Shakedown and not Chop-Shop's Week 0, it filled up too fast.
Unread 30-01-2015, 09:43
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
That's a hike. Sadly we aren't going to either. We never got a notification Week 0 registration was opening.
Not sure what we'll do that weekend but it might be useful to us if we aren't spending 3-4 days getting ourselves ready for a competition but continue focusing on the robot for the first event.
1058 PVC Pirates 2016 - xxxx
Unread 30-01-2015, 12:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Getting there...
Unread 30-01-2015, 14:35
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
I love the idea of doing this post. It's amazing to see how much you guys progress over the season! Great job, Keep it up!!!
