Go to Post Success is the gleam in a child's eyes when they catch their first glimpse of your creation and their life is forever changed. - SlamminSammy [more]
Unread 30-01-2015, 10:39
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Relays only going backwards?
Originally Posted by hyprvx View Post
So we have one relay set on relay output 0, configured in both directions. We have boolean variables true if button 5 or 6 is held, respectively, and two while loops if those variables are true. In those loops, we have the relays set to trigger forwards or backwards, and when the code breaks out of those two loops, set back to off. The loop for backwards works perfectly; when I hold button 5, the relay triggers to go backwards. But button 6, when held, does nothing. We have stepped through the code with the debugger, and it's supposed to be setting the relay to forwards, but it does nothing. Help?
Our code is at https://github.com/caffeinatedDrummer/2151-Code
When you step through the code with the debugger does it attempt to execute the line that sets the relay to forward?
