Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 30-01-2015, 12:08
Dinnesy Dinnesy is offline
FRC #4968 (Robo Hawks)
Dinnesy is an unknown quantity at this point
Re: Code changes not deploying to robot?
Originally Posted by notmattlythgoe View Post
Oops, that should be (0, 1) not (0, 10).
yea, i figured that out myself lol. However it still did not fix the problem, which is rather weird.
Unread 30-01-2015, 12:11
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Hmmmm, that should have reversed it. Can you make sure the code saved and try it again?
Unread 30-01-2015, 12:26
I tested it with a System.out.println("Hello world"); and I can confirm that the code is being deployed.
Unread 30-01-2015, 12:29
Flywheel Police
Try this:
myRobot.arcadeDrive(stick.getY(), stick.getX());
If that doesn't work try:
myRobot.arcadeDrive(stick.getY(), -stick.getX());
Unread 30-01-2015, 12:50
Try this:
That fixed the problem! thank you so much for all the help
IF you wouldn't mind me picker your brain a little longer however, I notice that when We Drive the robot forward, the right motor turns starts sooner and goes faster, and when we drive it backwards the left one starts sooner and goes faster.
Could this be because we have all the motors motors hooked up with the same polarity, thus when one side of the motors are going forward, the other side's motors are technically going backwards causing a slight delay?
Flywheel Police
Could this be because we have all the motors motors hooked up with the same polarity, thus when one side of the motors are going forward, the other side's motors are technically going backwards?
That is exactly correct.
Unread 30-01-2015, 13:11
Alright. Did As I said I would and everything works great. I'd like to thank you a lot a lot as well as everyone else who gave us a hand with our issue.
Unread 30-01-2015, 13:12
Flywheel Police
Absolutely. If you need anything else create a thread and shoot me a PM to let me know its there.
