Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 29-01-2015, 20:47
HannahtB HannahtB is offline
FRC #3229
HannahtB is an unknown quantity at this point
Problems with 20/20
On Wednesday our team received a shipment of 20/20 to build the frame of our robot. This is a normal thing for our team. This year our shipment came on time but the measurements were off. The diameter of the channel was .5 millimeters too small. Which would be usable except for the fact that the inner channel is also .5 millimeters too small. This means our sliders won't fit. We decided that we needed more sliders anyway and looked into getting more. They don't make any for the channel we got. Is anyone else having this problem or one similar?
Unread 30-01-2015, 09:51
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Problems with 20/20
I'm assuming you mean 80/20? What did you order? What did you receive? What sliders are you using?
Unread 30-01-2015, 09:55
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Were you expecting metric 80/20 or fractional 80/20? If you usually use fractional and got metric that could be the issue.
Here are what the 2 profiles look like.
Unread 30-01-2015, 12:04
FRC #3229
We are meeting this afternoon. I will post the pictures. The company said that whatever we got in the 20 series should work with the sliders. The rep I was speaking to plans to call us back today. When we ordered it there was only one option I believe.
Last edited by HannahtB : 30-01-2015 at 12:12. Reason: Misinformation by accident.
Unread 30-01-2015, 12:06
Andrew Duerner Andrew Duerner is offline
FRC #5818
Andrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud of
If your talking about the standard 1 inch profile, I have seen a thickness change also. The gearbox we make is designed with a snug fit that slides into the channel of the 80/20. This is sized to channel ordered from McMaster about 3 months ago. Some channel that was ordered from McMaster about 9 months ago shows a visible difference in the thickness of the extrusions. I haven't measured it but I think your about right on the change, about .010" - .020" decrease in thickness on the newer channel. One question, with thinner channel, why would your slide not work, besides being a little loose?
Andrew Duerner
Mechanical Engineer
Owner/Operator - www.armabot.com
Mentor FRC1717 2012-2013
Mentor FRC5818 2016
Armabot and FRC team involvement are unaffiliated.
Unread 30-01-2015, 12:17
FRC #3229
The sliders are too big. We had everything for the larger size.
Unread 30-01-2015, 12:27
FRC #3229
I have attached a picture that a team member sent me. I will get more detailed pictures in a few hours.
Unread 30-01-2015, 12:35
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
you probably just purchased 20-2020 (metric) series t-slot from 80/20.
I don't know what the one on the right is, but it looks a little different than 1010 (standard) series t-slot from 80/20, you might need to investigate where your previous t-slot came from?
Last edited by lcoreyl : 30-01-2015 at 12:42. Reason: actually looked at the picture...
Unread 30-01-2015, 12:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Based on their photo, it's more like that they have 25mm 80/20 extrusion:
http://www.mscdirect.com/product/det...S_010=01547645
1 inch = 25.4mm, so that would likely explain a ~0.5mm measured difference.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-01-2015, 12:58
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Both items in the photo show the metric-style hole pattern in the center of the piece.
Unread 30-01-2015, 13:00
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I don't think those pieces came from the same manufacturer. Is that a possibility?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Flywheel Police
Yeah, and the only other one that has the same hole pattern is the 3030, interesting.
Unread 30-01-2015, 13:06
FRC #3229
We ordered them both from 80/20. I will take exact measurements and get better pictures in an hour and a half.
Unread 30-01-2015, 13:07
Flywheel Police
These are all different extrusions that 80/20 offers.
Unread 30-01-2015, 13:34
lcoreyl's Avatar
AKA: Milner
the OP is calling what they just got 2020, which is why I make the assumption they have 80/20's 20-2020 series.
80/20's 25-2525 actually claims to have a slot max width difference of only about 1um from the 1010 series:
is 80/20 trying to slowly trick us ('Murica) into giving up our fractions??
