Go to Post Basically: engineering is fun. - Mike [more]
Unread 29-01-2015, 19:53
GortGortGort's Avatar
GortGortGort GortGortGort is offline
AKA: Lee Cole - Mentor
FRC #5040 (The BoltBots)
GortGortGort has a spectacular aura aboutGortGortGort has a spectacular aura about
Constructing a simple Two Drum Winch .
If your building a fork lift style entry this year most are using gears and chain or cables and winches. If your using a single drum winch just for lifting then your hoping gravity will pull down your lifting forks .
The advantages of a two drum cable winch for lifting totes is that one drum takes up the cable while the other plays it out and vice versa.
I thought I would share the steps of constructing a simple version of this winch with everyone .
The team I mentor is planning to use a Vex Planetary Gear box attached to this style winch .
Enjoy
http://frc.memphisfirstteams.org/201...nch/#more-3572
Unread 29-01-2015, 21:10
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Re: Constructing a simple Two Drum Winch .
Nicely done; thanks!
Unread 30-01-2015, 07:10
Thanks Chapman1 ,This design works on any hex shaft output gear box .
Unread 30-01-2015, 10:41
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Gort,
Thank you for posting this! Our team was using only one drum and this makes much more sense.
Could I ask a favor of you? We are setting up a site dedicated to helping teams find people with various FRC skills. Basically it is a searchable directory with contact options. If you'd be interested, we'd appreciate you checking it out and perhaps registering your skills at http://frcpitcrew.com
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 30-01-2015, 12:35
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Nice job!
Another option that removes the requirement to machine is to use AM hex hubs. Use an extended or 'long' shaft on your gear box and slide your hubs on.
Keep in mind that your wire / rope on the drums may not build up or release at the same rate as the diameter changes (if it overlaps itself on the drum). Many teams use a tension spring on the pull-down side to account for any inequalities between the drums.
Unread 30-01-2015, 13:48
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here is one of my favorite 2 drum winches of all time. This is from 2011. Can you tell who's it is? It should be obvious as they won on Einstein that year.
Unread 30-01-2015, 14:16
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
That's a 254 robot for sure. All the blue gives it away.
Unread 30-01-2015, 14:45
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
That and the "world champion 2011." Last time I checked, neither Wildstang nor Greybots did blue powdercoat (though I think I spotted some blue anodized parts on 111's 2014 bot).
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 31-01-2015, 05:22
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
We're using a single drum with a "continuous" loop of winch line to pull our forks both up and down. We have about five wraps of line around the drum. We use a small turnbuckle to make sure that the line is always tensioned properly. We used this approach successfully on our elevator in 2013 and our line never tangled or overlapped. Our drum that year was made out of ABS pipe screwed on to AM hubs. Last year our catapult winch used a 100% 3D printed ABS drum, no metal hubs required. It held up fine and we needed a lot of torque to retract our catapult. Used a hex bore on the drum because the ABS can't take the stress concentration in a square keyway. We're 3D printing our drum for this year's winch and we added helix grooves in it to guide the wraps.
"Genius is 1% inspiration, 99% perspiration"~Thomas Alva Edison
2016 Hawaii Regional Winners
Unread 31-01-2015, 07:11
Originally Posted by MysterE View Post
Gort,
I will be happy to help and will post my skills on your site this weekend .Just love that photo of team 254 robot that is a great example of the two drum winch used in FRC.
I have designed and erected several telescope enclosures such as domes and roll off roof observatories and these two drum winches are simple and very effective in opening shutter doors or rolling off huge roof structures weighting several thousand pounds. So it should have no trouble with a few totes and a garbage can.
I am currently making a 3 inch version of this winch and will post photos of its construction soon .
Unread 31-01-2015, 07:56
There is one design flaw with the winch that I original posted and I will post photos soon to correct this. It is not a flaw in the winch performance it deals
with the game itself . At the end of the game power is shut off , so if your lift is stuck up in the air your team will need to have a fast way to lower the lift manually . So I am currently replacing the nub shaft that was machined with a threaded hole that will have a 1/2 in bolt sticking through the support bearing and housing. This bolt will need to be cross drilled and cotter pin installed to prevent it from turning. This will allow the pit crew to safely ratchet the lift down with a socket and extension on a cordless drill. Sorry I guess that's why they make erasers on every pencil.
Unread 06-02-2015, 10:05
http://www.chiefdelphi.com/media/photos/41279?
This is a new and improved two drum winch design . It will allow you to use a ratchet and socket to lower the lift once the power is cut at the end of the game if your stuck with 6 totes in the air. Cable guides from home depo are simple screen door bearing / track guide mounted at bottom and top of the frame above and below your load your lifting or pulling down.The
cables are directed to top side of drum one and bottom of drum two . No slack in ether cable is allowed .Then as # one drum is lifting drum #two is spooling out and vise versa . To prevent the tote load from placing stress on the motor a constant spring force will be pulling the lift in the upward motion . You could use your Vulcan spring freebie or some KOP Latex Tubing . Hope these Ideas help other teams with there designs.
Unread 12-02-2015, 16:49
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
One thing to keep in mind is how your cable stacks up on the drums. If it starts piling in one spot, the radius increases and it wants to haul in more cable per turn. If your un-spooling drum isn't keeping up, they're going to start fighting each other...and your winch will stall or something will break.
A continuous loop design, like you say, helps avoid this, especially if your drum is wide enough and your cables aligned well, as it will only keep one layer of wraps across the drum.
Better yet....have your lathe folks cut spiral lagging (round-bottom groove) into the drum surface so that the cable always sits where it is supposed to. As a crane guy, that's how you get pro at cables on drums.
Jim Browne, EIT
Team 1058 - PVC Pirates
Unread 12-02-2015, 19:04
Just thought I would post the two drum winch in action enjoy .
https://www.youtube.com/watch?v=tC0s...ature=youtu.be
Unread 18-02-2015, 08:49
I have posted this video to show how well the two drum winch works .
The lift we had previously prototype in alum. had to be replaced because
of its bending under attempting to lift 6 totes . The new lift painted red with new pneumatic arms should improve the overall performance of the robot. The winch shows no noticeable damage from about 4 hours of practice lifting .
https://www.youtube.com/watch?v=NOKR...ature=youtu.be
