Go to Post Engineering rules of thumb don't form the garbage that goes into the making of the robot. They take the garbage of the real world and turn it into more pure, if slightly diluted, data. - DampRobot [more]
Unread 30-01-2015, 14:40
PaulEleven PaulEleven is offline
FRC #5633 (Hyde Phoenix Robotix)
Team Role: CAD
Rookie Year: 2015
PaulEleven is an unknown quantity at this point
Load and Friction
Hello!
we're planning on using a vexpro double sprocket 1/2id round for pulling our lift(about 80lbs max load), can I just make it an idle sprocket with the vexpro tube stock+1/4 bolt, or do I need some bearings for the friction?
Paul
Unread 30-01-2015, 14:43
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Load and Friction
How do you intend to pull up your lift with an idle sprocket?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 30-01-2015, 14:46
Team Role: CAD
Rookie Year: 2015
The elevator is powered from a sprocket on the bottom of the lift, top is the idle one.
Unread 30-01-2015, 14:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You could do either. You might even be able to use an igus bushing, if you can figure out something the right size.
If you don't use a bearing, you probably want to use some grease on the bolt.
Unread 30-01-2015, 14:47
Team Role: CAD
Rookie Year: 2015
Igus bag only have 1/2id ones, maybe a bronze bushing?
Unread 30-01-2015, 14:51
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
You can do anything with enough torque, but short answer is I would recommend at least a press in brass or plastic bushing (cheap, and available from McMaster-Carr).
You could do the math to find out exactly what difference in friction there will be on the sprocket shaft, but I would worry more about wear. The sprockets you buy from AndyMark or Vex are made from aluminum. Aluminum does NOT wear well, even when anodized - a few hundred turns under load and I would expect it to seize on the shaft.
Unread 30-01-2015, 15:01
MrForbes's Avatar
AKA: Jim
I would also look at the hardware store, for a bronze or nylon bushing, they might have something that will fit.
http://www.lowes.com/pd_446416-37672...ductId=4483496
for example
Unread 30-01-2015, 15:53
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
To make the idler sprockets on our lift it took a little tinkering. We used a vex plate sprocket on a flanged bearing. Then we made spacers our of 3/16" aluminum by cutting a circle with a 2" or so hole saw, and then cut a 1-1/8" hole in the center of that. Those spacers took up the extra space on the surface of the bearing so that we could use a washer with 1/2"id and a clamping shaft collar to hold it all together. It just makes a sandwich of washers basically that allows the sprocket to be forced to stay in place but can still spin freely on the bearing.
Unread 30-01-2015, 19:05
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
New catch-phrase
Unread 30-01-2015, 19:47
Team Role: CAD
Rookie Year: 2015
Vex's nylon spacers? dril it out to 1/4 or 3/8?
http://www.vexrobotics.com/spacers.html
