Go to Post FIRST competitions are a microcosm of real world engineering projects. - KenWittlief [more]
Unread 30-01-2015, 14:40
PaulEleven PaulEleven is offline
FRC #5633 (Hyde Phoenix Robotix)
Team Role: CAD
Rookie Year: 2015
PaulEleven is an unknown quantity at this point
Load and Friction
Hello!
we're planning on using a vexpro double sprocket 1/2id round for pulling our lift(about 80lbs max load), can I just make it an idle sprocket with the vexpro tube stock+1/4 bolt, or do I need some bearings for the friction?
Paul
Unread 30-01-2015, 14:43
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Load and Friction
How do you intend to pull up your lift with an idle sprocket?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 30-01-2015, 14:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You could do either. You might even be able to use an igus bushing, if you can figure out something the right size.
If you don't use a bearing, you probably want to use some grease on the bolt.
Unread 30-01-2015, 14:46
Team Role: CAD
Rookie Year: 2015
The elevator is powered from a sprocket on the bottom of the lift, top is the idle one.
Unread 30-01-2015, 14:47
Team Role: CAD
Rookie Year: 2015
Igus bag only have 1/2id ones, maybe a bronze bushing?
Unread 30-01-2015, 14:51
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
You can do anything with enough torque, but short answer is I would recommend at least a press in brass or plastic bushing (cheap, and available from McMaster-Carr).
You could do the math to find out exactly what difference in friction there will be on the sprocket shaft, but I would worry more about wear. The sprockets you buy from AndyMark or Vex are made from aluminum. Aluminum does NOT wear well, even when anodized - a few hundred turns under load and I would expect it to seize on the shaft.
Unread 30-01-2015, 15:01
MrForbes's Avatar
AKA: Jim
I would also look at the hardware store, for a bronze or nylon bushing, they might have something that will fit.
http://www.lowes.com/pd_446416-37672...ductId=4483496
for example
Unread 30-01-2015, 15:53
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
To make the idler sprockets on our lift it took a little tinkering. We used a vex plate sprocket on a flanged bearing. Then we made spacers our of 3/16" aluminum by cutting a circle with a 2" or so hole saw, and then cut a 1-1/8" hole in the center of that. Those spacers took up the extra space on the surface of the bearing so that we could use a washer with 1/2"id and a clamping shaft collar to hold it all together. It just makes a sandwich of washers basically that allows the sprocket to be forced to stay in place but can still spin freely on the bearing.
Unread 30-01-2015, 19:05
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
New catch-phrase
Unread 30-01-2015, 19:47
Team Role: CAD
Rookie Year: 2015
Vex's nylon spacers? dril it out to 1/4 or 3/8?
http://www.vexrobotics.com/spacers.html
