Re: Where to buy Omni Wheels 6"
Never mind. Please delete.
If they're unpowered, why not opt for a different size Omni wheel in that location? When functioning essentially as a caster, the diameter shouldn't matter so long as the wheel is touching the floor. It may require some modification to your bearing/axle mount, but depending on your design that may not be a big deal.
Alternatively, you could double up on the AndyMark omnis to further distribute the load on each wheel. |
![]() Edit: He said if there are no alternatives to getting 6" wheels to match we may go with the 8" ones. The main concern is our robot and how it may not be parallel to the ground. Also we don't want to do the machining for the 8", we would like to stay away from machining it as much as possible. Last edited by Asymons : 30-01-2015 at 15:36. |
