Go to Post One team at the UTC regional scored over 2100 points in autonomous alone. I was highly impressed. - Greg Marra [more]
Unread 30-01-2015, 15:32
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Asymons is an unknown quantity at this point
Re: Where to buy Omni Wheels 6"
Originally Posted by Lil' Lavery View Post
If they're unpowered, why not opt for a different size Omni wheel in that location? When functioning essentially as a caster, the diameter shouldn't matter so long as the wheel is touching the floor. It may require some modification to your bearing/axle mount, but depending on your design that may not be a big deal.
Alternatively, you could double up on the AndyMark omnis to further distribute the load on each wheel.
Thank you for the suggestion. Our design may not be able to double up on the wheels, but I will ask our mentor if incorporating a difference wheel size would work for our design of the robot. I shall update the post once I get his answer. Thank you
Edit: He said if there are no alternatives to getting 6" wheels to match we may go with the 8" ones. The main concern is our robot and how it may not be parallel to the ground. Also we don't want to do the machining for the 8", we would like to stay away from machining it as much as possible.
