Go to Post Dwelling on the past does nothing for the future. - Cory [more]
Unread 30-01-2015, 12:34
2386programming 2386programming is offline
FRC #2386 (Trojans)
2386programming is an unknown quantity at this point
Encoders With Motor Speeds
Hello, my team is programming the drive train for this years robot and all the gear boxes move at different speeds. We are trying to figure out a way to get a value from the encoders for inches per second per say, and then send readings to our talons making all the wheels spin at the same speed.
Unread 30-01-2015, 12:35
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Encoders With Motor Speeds
Are you using the new Talons or the older ones?
Unread 30-01-2015, 12:39
FRC #2386 (Trojans)
We're using the old ones.
Unread 30-01-2015, 12:40
Flywheel Police
What programming structure are you using? Iterative, Sample, or Command?
Unread 30-01-2015, 12:41
FRC #2386 (Trojans)
We're using an iterative structure
Unread 30-01-2015, 12:49
Flywheel Police
What you'll want to do is look at the Encoder class and make sure to configure the distancePerPulse. Then you will pass that encoder into a PIDController along with the motor you want to control with it.
PIDController leftFrontWheel = new PIDController(p, i, d, leftFrontEncoder, leftFrontTalon);
Unread 30-01-2015, 16:38
FRC #2386 (Trojans)
Great thank you! Is there any way that you could help and explain how a PID controller actually works in layman's terms?
Unread 30-01-2015, 17:07
Watch this video.
